How do you check mafs
Vagcom the car fairly often and suprised ive never lost one,do you have to do a power run and use the results to check the maf?
RE: How do you check mafs
yup that is what i have done - 3rd gear log from 2k to limiter
Unplug it.; If the cars runs same or better, it is stuffed.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
- 5th Gear
you can check maf on vag as long as the car is fairly std. do it then post your logs. i think a std rs4 maxxes out the maf at 330 g/s ish, so just see what it does .
665 bhp + 586 lbft...
Thanks fellas, I will try this out when i have her back in action,im pretty sure all is ok as its always performed well,but after replacing the pre cat lambdas thought it a good idea to check
Some of the MAF's are crap. It is worthwhile checking periodically. Audi do exchange units quit cheap.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Users browsing this forum: Google [Bot] and 41 guests
