I am having a clear out! (much needed) all got to go
all parts off a late 1999 1.8tqs avant unless stated
1 rear facelift bumper in silver (slight scuff that needs attention otherwise just needs a clean)
1 set front facelift bumper hangers (plastic triangle that bolts to the wing) with inner trim
1 rear set facelift bumper hangers
1 front bumper bar (metal inner)
1 inner lock cover from the boot of an avant (first thing you see when you look down, covers lock and protects the lip.
2 electric wing mirrors (fully working in silver) -
2 mint condition rear door outer sail trims in gloss black. (£35 a pair from audi) replace those corroded ones on your car - £15 posted
3 front uprights/hub carriers with hub flange, good bearings (1 is a bit rusty, came from a 2WD vehicle)
2 front calipers with hoses (discs if you want them but they are only standard vented items)
2 rear calipers with discs
2 B5 RS4 front caliper protector plates (also acts as a duct for cooling), fits most A4/S4/RS4 struts
full set of shocks and springs for a 1.8tqs avant
very good condition, sport up your SE or non sport quattro. pretty sure they are a straight swap onto a saloon.
1 Stock Side mount Intercooler and associated hoses including TIP
1 engine cover (stock 20v item)
1 engine undertray, usual scuffs, nothing major SOLD
1 cam belt tensioner, fitted, run for 500 miles, car written off, very shiny.
2 RS4 drive shafts (no CV's, can supply the inners if needed)
Full quattro sport exhaust system (have the CAT somewhere, just can't find it at the moment!)
5 OEM 18x8J ET43 RS6 5 Spokes, all straight and balanced but in need a refurb, may have them refurbed myself unless I get a decent offer as they are.
will update if I stumble across anything else!!
PM or email ed@ersg.com
lots of B5 parts for sale
