Tyre Pressure coding
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
tartan_rob
Post by tartan_rob » Tue Dec 02, 2008 10:17 am
Does anyone know the procedure for coding in new tyre pressure sensors?
2017 Kawasaki Z1000
2014 RS6
2014 S1
PetrolDave
RE: Tyre Pressure coding
Post by PetrolDave » Tue Dec 02, 2008 6:55 pm
The Ross Tech wiki only shows coding - is there a special procedure?
http://wiki.ross-tech.com/index.php/Aud ... Monitoring
tartan_rob
Post by tartan_rob » Wed Dec 03, 2008 9:35 am
I assumed there was, perhaps not.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Sebastian
Post by Sebastian » Wed Dec 03, 2008 2:09 pm
If in doubt check the factory repair manual.
Sebastian @ Ross-Tech.com
tartan_rob
Post by tartan_rob » Fri Jan 02, 2009 11:34 am
Once fitted new/replacement sensors, go into VAG-com and select Adaptation on Tire Pressure Monitor, save Channel0, that resets factory defaults and initiates a learning function to learn the new values of TPS.
Voila.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 26 guests
