MY2006 BBS on facelift s4
i plan on fitting the bbs from my06 s4 onto the b5 s4. does anyone know what size spacer i will need ? the bbs are et45.
how wide are they?
The B5 S4 standard wheels are 7.5" wide and ET45 and you should be trying to keep it as close to this as possible for best handling. However if the wheels are wider you will need to lower the offset to make them fit, as they'll hit the suspension knuckle, on the rear especially!
You might get away with a 5mm spacer if they're 8" wide, depending on tyre choice, or you may have to use a 10mm one. I'd try to keep the spacer as thin as possible though, to keep it handling properly!
