new boots
al'srs4
new boots
Post by al'srs4 » Fri Nov 14, 2008 11:56 am
Just about to by some new tyres: Goodyear Asymmetric in 275/30 x 19
Can anyone tell me if the above size is okay for all four corners or are the ones at the back different? I guess they should be the same, only these are slightly over sized to fill the arches so a bit unsure what I should be ordering.
Cheers alex
R32 DPB 58 (bl**dy recession)
RS4 Avus Saloon (07) B7 (RIP)
M3 Conv (feel the rays)
M3 Saloon (back in the saddle- yes)
325i M sport (my wife's idea)
Impreza STi V5 (cheap Jap power-great)
sonny
RE: new boots
Post by sonny » Fri Nov 14, 2008 12:33 pm
All 4 tyrs should be the same due to the 4wd (someone correct me if im wrong)!
RS44ME
RE: new boots
Post by RS44ME » Fri Nov 14, 2008 12:34 pm
Further, could anyone show us some pics of what the B7 RS4 looks like with 275/30R19s ?
Also, how much does this put the speedometer out by ?
PetrolDave
Re: RE: new boots
Post by PetrolDave » Fri Nov 14, 2008 1:26 pm
RS44ME wrote:Further, could anyone show us some pics of what the B7 RS4 looks like with 275/30R19s ?
IIRC there's already some pics on here.
The speedo over-reads by a further 2%, since the RS4 already over-reads by about 5% that makes it about 7% (still within the C&U Regs limit of 10%).
FWIW my previous S4s have had much more accurate spedos which over-read by only 2%.
All values compared to a GPS speedo.
al'srs4
RE: Re: RE: new boots
Post by al'srs4 » Fri Nov 14, 2008 1:43 pm
Be very interested to see any pics, does anyone have a link or jpeg handy!
:D
RS44ME
Post by RS44ME » Fri Nov 14, 2008 2:09 pm
Just spent 30 minutes searching and trawling this site and others - cannot find any B7 pics with 275s - all help, pics or links welcome
RS44ME
Post by RS44ME » Fri Nov 14, 2008 2:10 pm
PetrolDave - thanks for the speedo info !
PetrolDave
Post by PetrolDave » Fri Nov 14, 2008 2:33 pm
Try here http://forums.audiworld.com/rs4b7/msgs/82085.phtml
They're not Goodyears but they are 275/30 19s
Andyuk911
Post by Andyuk911 » Fri Nov 14, 2008 3:19 pm
RS4 Avant - Sold Aug 2009
Dom81
Re: RE: new boots
Post by Dom81 » Fri Nov 14, 2008 4:36 pm
PetrolDave wrote:FWIW my previous S4s have had much more accurate spedos which over-read by only 2%.
My findings exactly...
2007 Daytona RS4 Avant
al'srs4
Post by al'srs4 » Fri Nov 14, 2008 8:07 pm
Some interesting threads/links. Does anyone know if the tyre pressure differs fitting these wider tyres to the smaller spec rim.
P_G
Post by P_G » Fri Nov 14, 2008 8:10 pm
I'm running mine at 39 front and 38 rear after some toying around with pressures, gives good grip without making the ride uncomfortable and feeling every bit of aggregate in the road when at higher pressures with associated noise.
PetrolDave
Post by PetrolDave » Fri Nov 14, 2008 8:14 pm
P_G wrote:I'm running mine at 39 front and 38 rear
Same here - and I've recoded the TPMS to reflect the higher pressures I'm running.
P_G
Post by P_G » Fri Nov 14, 2008 8:21 pm
Recoded? Do you just not reset your TPMS vis DIS ASAP RSVP? :wink:
PetrolDave
Post by PetrolDave » Fri Nov 14, 2008 8:35 pm
P_G wrote:Recoded? Do you just not reset your TPMS vis DIS ASAP RSVP? :wink:
Not if you want it to alarm at the same difference from your new "normal" pressures.
See here http://wiki.ross-tech.com/index.php/Aud ... Monitoring
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 460 guests
