EGT fault and another?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
bobbler
Post by bobbler » Tue Nov 11, 2008 9:42 pm
Need a hand with these codes if possible.
1st one is an EGT (drivers side by the looks of things too for an easy fix :) ) but the second one I am not sure what that is. Is it just a case of I fix the EGT and it will go too?
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
P1462 - 35-10 - - - Intermittent
Also where's the best place (cheapest!) to get it from?
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
DutchRS4
RE: EGT fault and another?
Post by DutchRS4 » Thu Nov 13, 2008 7:16 pm
yes. Those 2 errors are basically saying:
1: problem with the EGT sensor
2: faulty reading because of the defect EGT
2001 Avus Silver RS4 with 60k miles
100 cpsi full Milltek
710N DV
Awe Tuning Center Vent Boost Gauge
N249 delete
bobbler
Post by bobbler » Fri Nov 14, 2008 1:47 am
Thanks Dutch, just wanted to be sure that I don't need something on top of the EGT.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 43 guests
