B5 RS4 rear calipers on a facelift S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
NeilMc
Post by NeilMc » Wed Nov 05, 2008 11:25 pm
Does anyone know if any modifications need to be done to a late facelift S4 to fit B5 RS4 rear calipers? When looking at the parts side by side, I can't see any major difference.
The reason for all this is that I need to get my rear calipers refurbed and I have a set of B5 RS4 rears spare that also need a refurb. Ideally I'd like to send the RS4 calipers away to be done and then fit them to my car when they come back. That way my car isn't off the road waiting for calipers. I can only do this if they will fit though.
2000 Nogaro S4 Saloon
Blue_Thunder
RE: B5 RS4 rear calipers on a facelift S4
Post by Blue_Thunder » Wed Nov 05, 2008 11:40 pm
They are the same calipers I believe.
NeilMc
Post by NeilMc » Thu Nov 06, 2008 12:07 am
That would be good news!
UKS4APR1
Post by UKS4APR1 » Thu Nov 06, 2008 1:24 am
Possibly RS4 calipers have a different brake pipe (flexy) banjo fitting, they will not fit your S4 unless you also have the flexy brake pipe to suit as well. I know that's the case with pre-facelift cars.
Obviously RS4 calipers on their brackets fit very much larger dia discs.
par_s4
Post by par_s4 » Thu Nov 06, 2008 9:54 pm
The calipers assemblies are identical except for the finish, and an anti rotation pin which prevents the banjo fitting on the RS4 flexi pipe from rotating and loosening the connection. The the pin is fittend in a hole drilled in a boss cast in the caliper body. The boss is evident on both facelift S4 and RS4 calipers, but only the RS4 ones have the hole drilled to accept the pin. This would however be a simple thing to do DIY with a little care.
2000 S4 Avant | Santorin Blue | 710Ns | Short Shift | R8 Replicas | B5 RS4 Brakes
NeilMc
Post by NeilMc » Fri Nov 07, 2008 12:46 am
Thanks guys, I think that's enough information for me to go ahead with the RS4 calipers.
jc..
Post by jc.. » Sat Nov 15, 2008 2:01 pm
I have two B5 rears hoses if you are interested. just fitted braided to mine.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 97 guests
