wanted vag-com
wanted vag-com
carps showed me his vag-com and i've just got to have one!! where can i buy one new and how much are they? [img]images/graemlins/s4addict.gif[/img]
Re: wanted vag-com
You can get Vag-com from here
Always check your nuts before you have a play ! [img]images/graemlins/crazy.gif[/img]
Re: wanted vag-com
nice one cheers matey [img]images/graemlins/thumb.gif[/img] all i need now is a decent lap top!
Re: wanted vag-com
Then be careful with the Vag-Com version you buy.
If you take the cheaper Serial Port version (vs. the USB one), be aware that many notebooks do not have a serial port anymore.
if you go for the serial port version, Dell makes one which is a pretty good/light/decent autonomy/decent price, called the Inspiron 500m.
But for example, the cheaper/heavier Inspiron 1100 does NOT have a serial port.
Eric
PS : if you ever go for Revo, it seems their optional "advanced tuning kit" also requires a serial port as of today. You may want to verify that too. But in any case, I'd go for a notebook WITH a serial port to keep maximum options open.
Eric
- RS4 V6 Biturbo Imola Yellow (2001)
• Custom MTM 460hp manually tuned by Peter Link on MTM dyno at Ingolstadt HQ.
• Custom Full Milltek: Sport-Cats / Mid-Silencer: suppressed / End-Silencer: reduced.
• Full Mov'It upgrade: Front 380mm - 6 pistons / Rear 220mm - 4 pistons / Parking addon.
- Joined the Dark Side (aka. Darth Elon) circa 2013.
Re: wanted vag-com
i will look out for that!! cheers [img]images/graemlins/thumb.gif[/img]
Re: wanted vag-com
there's always usb to serial converters - I use one on my acer laptop to talk to serial devices.. appears as a normal COM port so most software should work with it.
R
R
Ex '98 S4, Red, Bose
RS4 to be [img]images/graemlins/smile.gif[/img]
Re: wanted vag-com
My laptop doesnt have a serial port and i have tried using usb to serial convertors and unfortunately the Vag com does not work with these converters unless u buy the very expensive one.
My DVD System
Re: wanted vag-com
There's some info in Ross-Tech's FAQ here
Users browsing this forum: No registered users and 74 guests
