VAG-COM help
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
bobjebb
VAG-COM help
Post by bobjebb » Mon Oct 27, 2008 6:16 pm
Hi
Does anyone have the box of tricks near the A4 Wilts/Berks area?
I've got a fault with the parking sensor, which is mentioned in the manual actually so obviously not that unusual. Anyone ever had this?
I'm getting a long beep once they activate for the first time and the LED in the button is flashing.
Hopefully this is something that can be reset?
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
davejel
Post by davejel » Mon Oct 27, 2008 8:59 pm
Mine did exactly the same for 2 or 3 days a while ago, but seems to have cured itself, and is working fine now.
skiwi
Post by skiwi » Tue Oct 28, 2008 12:23 am
most likely logged a fault code. are both ends n/w? had any fender benders that might have disconnected a sensor?
bobjebb
Post by bobjebb » Tue Oct 28, 2008 1:38 am
only tried reverse, but I'd guess it was both ends! No bumps, sensors all intact. It first did it when I collected after service. Seems odd that the manual refers to it happening.
Back with C6 RS6
And again C7 RS6
skiwi
Post by skiwi » Wed Oct 29, 2008 10:52 am
easiest to check with vdcs, but if you don't have it, do a quick visual of the wiring.
they are difficult to service without removing the bumper skin. the rear is pretty straight forward, maybe 30 mins work (6 nuts and a few torx bolts. audiworld has a good writeup. when you remove the skin you will see the sensors and their wiring.
bobjebb
Post by bobjebb » Fri Nov 28, 2008 11:42 am
still looking, swindon berks hants sort of area! Parking sensor problem. Cheers
Back with C6 RS6
And again C7 RS6
Return to “DTC / VCDS”
