RNS-E Satellites reception problem
andyt
Post by andyt » Sat Oct 18, 2008 9:51 pm
My RNS-E seems to get lost quite a lot. Some days it simply thinks I'm driving across fields (I'm not BTW). When I press Nav-Info, it says 0 satellites found. Even when it appears to be working, I get 3 or at the most 4 satellites found. Is the aerial a bit knackered? This is an RNS-E retroft that <cough> I did myself and AFAIK it's always only got 3 or 4 sats but the 0 sat seems to be happening more lately. What's the likely problem? What can I look for? If I VAG-COM it, I do get an error:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
But I'm led to believe that's not relevant.
Any ideas? Thanks.
Virdee Autos
Trader (Expired)
RE: RNS-E Satellites reception problem
Post by Virdee Autos » Sat Oct 18, 2008 10:12 pm
AFAIK that fault code is for the radio antenna itself
Could be a dodgy GPS antenna or it has gone tits up
Virdee Autos ~ 07950-526592
craigyb
Post by craigyb » Sun Oct 19, 2008 9:55 am
Where is it located, it may simply have come loose and slipped down somewhere, I have seen that a lot.
andyt
Post by andyt » Sun Oct 19, 2008 2:40 pm
Er.. when I fitted the RNS-E, I connected the GPS aerial to the existing one that the RNS-D used, which I believe uses the sharkfin on the roof. The car is an RS6 (sorry, I was forgetting I wasn't in the RS6 bit of the forum!). Do you think it would work better if I just used a standard aerial?
craigyb
Post by craigyb » Sun Oct 19, 2008 3:41 pm
Ok, that makes more sense, should be rock solid, but the GPS antennas on A6/RS6/S6's are known for problems. Mine failed at 18 months old.
Pop one behind the clocks with a proper FAKRA connector.
andyt
Post by andyt » Mon Oct 20, 2008 10:46 pm
OK cheers Craig. I'll look into trying a different aerial and see if it improves. I guess it should be easy enough to do a before/after test.
johnny11
Post by johnny11 » Tue Oct 28, 2008 3:33 pm
mine started doing this a few months before the sat nav unit failed.
Return to “Electrical”
