C5 RS6 door open signal
tartan_rob
Post by tartan_rob » Fri Oct 03, 2008 1:25 pm
My rear door does not show up on the DIS when it is opened also the welcome lights in the door do not come on either. I suspect it is not getting the signal to say 'door open'. In the good 'ole days this would have been a simple switch...
Also the welcome light in the boot does not and the bulb is okay. It appears not to be getting the signal to say 'boot open'....
Rob
2017 Kawasaki Z1000
2014 RS6
2014 S1
GardinerG
RE: C5 RS6 door open signal
Post by GardinerG » Fri Oct 03, 2008 7:30 pm
Yeah, the door shut sensor is part of the door locking mechanism.
tartan_rob
Post by tartan_rob » Sat Oct 04, 2008 4:54 pm
So its a panel off job to fix?
2017 Kawasaki Z1000
2014 RS6
2014 S1
GardinerG
Post by GardinerG » Sat Oct 04, 2008 5:02 pm
That's if it is the sensor, I'm not sure how it works but I would imagine that if the wiring was shot you would get the door open signal?
But, yes removing the door lock is a door panel off jobbie.
I know some have fixed the locking mechanism once they have removed it from the door.
tartan_rob
Post by tartan_rob » Sat Oct 04, 2008 6:35 pm
Funny though, if you open the door, although the courtesy light in the door do not come on and the DIS does not register the door open, the interior lights come on. All other doors etc behave as normal.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “Electrical”
