Battery
Battery
Folks
This morning i went to get something out of the RS and noticed that everything was a bit dull (dash/interior light). The Battery is flat. The Battery is only 18 months old (Bosch). i went on holiday a couple of months ago, and it was flat after 2 weeks. Ok, I thought, that's possible, charged it and away I went. This time, it has only been sitting since Friday. It should not be flat already.
Do I have a drain? Where do I start looking?
Thanks!
Thanks!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
- rsmonkey918
RE: Battery
Morning Norrs, might be worth getting it checked- had a similar problem in the past and it was down to a faulty cell. Failing that possibly related to the alternator?? You probably need someone with a bit more tech knowledge......
Steve
Steve
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
Re: RE: Battery
Yes i do! Related?mbelle wrote:Do you have Nav Plus+TV?
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
RE: Re: RE: Battery
Happened a few times on my old S4 - the kids know better then to mess with the lights now!Last time mine went flat, which was a few weeks back, the kids had left the small lights on in the back. Long shot, I know, but it was an easy fix.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: RE: Battery
Possibly - mine has gone flat on one occasion as well.Norrs2 wrote:Yes i do! Related?mbelle wrote:Do you have Nav Plus+TV?
When you switch of the engine and remove the key from the ignition, your Nav unit turns itself off after ~2-3secs (mine can be heard as a slight deep clunk from the N/S rear boot area, obvisouly, as it is located there).
On this one occasion, I pulled up in my drive and continued watching TV for ~1min, then removed the key from the ignition i.e. the last function my unit was in was TV.
I don't recall hearing the unit switch itself off (although my display went out) - next morning, battery was flat.
Now, I never leave it on TV when removing the key from the ignition, and always listen to ensure the unit switches itself off...
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
- Virdee Autos
- Trader (Expired)
RE: Re: RE: Battery
Best to get your battery and alternator checked, and then if all is good, you need to check the battery drainage ideally with a tong tester on the battery, and pull out each fuse individually, and see if the value drops. If it does, then check what that fuse is for.
Thats a starting point!
Virdee Autos ~ 07950-526592
RE: Re: RE: Battery
My last Bosch battery ( fitted to a ' seasonal ' Ford ) lasted 12 years
It must be a 23rd September feature; mine was flat yesterday too! And as it's less than 2 years with old "no previous" I was surprised. Car had only stood 2 days since it had a fairly decent outing. As far as I can see nothing left on and no TV, though it does have Nav+, but will see if it repeats now it's been charged and investigate from there.
...PaulR.
...PaulR.
PaulR wrote:It must be a 23rd September feature; mine was flat yesterday too!
...PaulR.
Thanks for the responses guys. Thanks Virdee, I'll get it checked out.
I'll report back any findings.
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
