DRC Issue - what is there to know?
TEE
Post by TEE » Mon Sep 22, 2008 11:13 am
Hi I am trying to get caught on the DRC issue on this thread. What is the issue and what are the steps to be taken. Although I am in Germany now this should not be a UK issue I assume.
What are the concessions from AUdi UK so I can try to secure the same here in GErmany.
TEE
Dom81
RE: DRC Issue - what is there to know?
Post by Dom81 » Tue Sep 23, 2008 12:06 am
Tee - a quick search on DRC will give you all there is to know. No need to repeat everything...
Good luck
2007 Daytona RS4 Avant
RS Owner
Post by RS Owner » Fri Dec 26, 2008 4:05 pm
I have the same question and after faffing around I discovered DRC is "Dynamic Ride Control" and is often used to refer to faults with the shock absorbers.
PetrolDave
Post by PetrolDave » Fri Dec 26, 2008 7:29 pm
If you own an RS4 and don't know what DRC is then shame on you! DRC is one of the things that distinguishes RS models from S & A models, so if you don't know what it is then why are you driving an RS?
As already said all the information about what the DRC problem is, how it can be seen, what Audi have done to help, which dealers know about the problem and which don't have a clue, etc has been posted here in full detail and there's really no point posting it all again.
Spurian
Post by Spurian » Fri Dec 26, 2008 7:47 pm
Doing a search yields 172 threads which seems like a lot. It seems like a useful thing to do would be to create a "sticky" thread with relevant info.
P_G
Post by P_G » Fri Dec 26, 2008 8:21 pm
Long and the short of it, DRC is not just the shocks, it is a hydraulic system linked to the shock absorbers on opposite corners to improve handling and cornering at speed
Faults could be with leaking shocks, fluid evident on the shocks themselves with inspection; or with DRC valves. Audi UK have given a 5 year of 70k mile extended warranty on new shocks should they need replacing but only if you ask and they will only be replaced if leaking, residue on the shocks is seen as within normal operating parameters.
Users browsing this forum: Zyox and 217 guests
