Wich gear on rolling road
Is it normaly to run the car in 6. gear on a rollingroad?
Blue_Thunder
- Top Gear
Blue_Thunder
- Top Gear
Yes thats true, but my BMW is doing 170 mph at the red line and it was done in 5th gear.
Also remember that the power quoted will change depending on what gear you use as the transmission loss and general heat loss and friction is higher in higher gears. The coast down doesn't always compensate for this properly. You should always use the same gear for direct comparisons.
If your car jumps off the rollers even in 2nd gear then its going to be a write off no matter what.
Blue_Thunder
- Top Gear
Maybe not - http://www.youtube.com/watch?v=p4l-Dl73TpM&NR=1MGR wrote:If your car jumps off the rollers even in 2nd gear then its going to be a write off no matter what.
Blue_Thunder
- Top Gear
And from that, just found this clip. Hilarious!
http://www.youtube.com/watch?v=GSl-jSfn ... re=related
Poor old sod!
Poor old sod!
Oh dear - I suppose that comment was meant if it was properly strapped down so it can't move, and so the only way it is coming off is if the rollers jam.Blue_Thunder wrote:Maybe not - http://www.youtube.com/watch?v=p4l-Dl73TpM&NR=1MGR wrote:If your car jumps off the rollers even in 2nd gear then its going to be a write off no matter what.
Users browsing this forum: No registered users and 225 guests
