Location of EModule
2.7 V6 30v biturbo - 380 bhp
gb
Location of EModule
Post by gb » Sat Sep 13, 2008 7:14 am
Hi everyone.
Appreciate if someone could tell me where the ECU module is located in these cars.
Thanks in anticipation :)
Regards,
GB from downunder
andream88
RE: Location of EModule
Post by andream88 » Sat Sep 13, 2008 9:59 am
Open the hood.
Take off the seal between the engine and the battery cover.
Now remove the plastic piece over the battery (together with the battery cover) and brakes fluid reservoir.
You will see a black box (i have it on the driver side, LHD car) sealed by a few torx screws.
Unscrew them (you don't need to remove the wipers, just use an angled wrench), pull the ECU cover.
ET VOILA'.
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
Users browsing this forum: No registered users and 27 guests
