Drain Holes!!!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
GDS968
Drain Holes!!!
Post by GDS968 » Fri Sep 05, 2008 3:21 pm
Just had the windscreen rplaced on my S4 and noticed that the area immediately below the screen by the ECU seems to have rather a lot of water in it, should there be drain holes here chaps and if so where, cause I can't see them. cheers
frazered
RE: Drain Holes!!!
Post by frazered » Fri Sep 05, 2008 3:35 pm
under the battery - it often gets clogged up, you need to take the battery out and then unblock - i have used compressed air to do that in the past or just a finger
Nige_RS4
Re: RE: Drain Holes!!!
Post by Nige_RS4 » Fri Sep 05, 2008 4:07 pm
frazered wrote:under the battery - it often gets clogged up, you need to take the battery out and then unblock - i have used compressed air to do that in the past or just a finger
Or you can remove it from underneath the car.
BTW, there is another drain plug somewhere on the bulkhead.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
philipwalker
RE: Re: RE: Drain Holes!!!
Post by philipwalker » Fri Sep 05, 2008 4:51 pm
There are two drains on the B5.
One under the battery and the other under the servo.
Stick you finger in the "hole" to clear.
http://www.pwmotorsport.com
PW Motorsport
01437 563929
andybnwc
Post by andybnwc » Sat Sep 06, 2008 11:34 am
Very lucky to catch it in time before you get wet passenger side footwells ,where i am its been raining really bad lately
imolas4uk
Post by imolas4uk » Sat Sep 06, 2008 11:43 pm
if you take out the rubber grometts this will never happen again :thumbs:
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sun Sep 07, 2008 4:04 pm
Take out the rubber grommets, and then cut the "flower" part of the grommet. So that way you still have the rubber grommet in place, so thus no rust issues, but water will still get through
Virdee Autos ~ 07950-526592
GDS968
Post by GDS968 » Mon Sep 08, 2008 2:22 pm
Cheers chaps for all the advice, will sort it!
KayGee
Post by KayGee » Mon Sep 08, 2008 3:08 pm
I clear mine twice a year, after a footwell full of water experience......
chubbs358
Post by chubbs358 » Tue Jun 09, 2009 5:03 pm
just found recently i seem to have a fair bit of rust in this area :( is that a comon area to get rust on a B5 or is it likely that sum one has had a batter leak/broken in ther it sux :evil:
Users browsing this forum: Google [Bot] and 99 guests
