Torque wrench for RS4
Ozrs4
Post by Ozrs4 » Tue Aug 26, 2008 2:12 am
Guys, does anyone know the torque amount to tighten our wheel nuts on the RS4? Does anyone bother or do you all just tighten it as hard as you can? Thanks.
ChrisRS4
RE: Torque wrench for RS4
Post by ChrisRS4 » Tue Aug 26, 2008 7:00 am
IIRC its 120nm for wheel bolts.
rjkflyer
Post by rjkflyer » Tue Aug 26, 2008 8:49 am
Yep, 120Nm for the RS4 8E, and 140Nm for the RS4 8D. From the Audi Workshop manual.
rjkflyer
Post by rjkflyer » Tue Aug 26, 2008 8:53 am
And NO, NOT as TIGHT AS YOU CAN. If you use excessive torque the bolts can actually come UNDONE.
Why? Because if you stress steel too much it hardens. Correct operation of bolts assumes that there is some elasticity in the material so that when you tighten them correctly they exert some 'self-tightening' due to the elasticity. If they're grossly overtightened esp. repeatedly, then they are so hard they don't have an elasticity (they've gone beyond their 'elastic limit') and so no matter how tight you do them up they can work loose.
Ozrs4
Post by Ozrs4 » Tue Aug 26, 2008 9:04 am
Thanks all. I'll be getting a torque wrench and a proper hydraulic jack so I can take the wheels off for proper cleaning and to check on any future leaking shock (I don't have too much faith with this leaking shocks issue).
2007 RS4 B7 - Phantom black saloon
dom888
Post by dom888 » Tue Aug 26, 2008 12:23 pm
I'm looking at buying a torque wrench of Fleabay. Do I need a 1/2" or 3/8" one? And apart from buying one that goes up to the required 140nM, is there anything else I need to ensure?
PetrolDave
Post by PetrolDave » Tue Aug 26, 2008 1:01 pm
I would go for the 1/2" one - it's less likely to shear.
I sheared a 3/8" drive socket while trying to undo the wheel nuts on a previous car (that had been done up with an air wrench by a tyre fitter).
pippyrips
Post by pippyrips » Tue Aug 26, 2008 2:52 pm
Try MachineMart a stand alone torque wrench, then need a separate, thin walled socket. From memory its 13mm but sure others will confirm.
PetrolDave
Post by PetrolDave » Tue Aug 26, 2008 5:37 pm
I thought it was 19mm?
rjkflyer
Post by rjkflyer » Tue Aug 26, 2008 8:30 pm
Most Audi wheel bolts are 17mm.
Suggest you get a deep 6-point (as opposed to 12-point) socket, which means it's nice and long to get into the wheel bolt 'hole' without scuffing the wheel with the torque wrench itself and also 6-point stronger and 'looks' like a nut as opposed to a 12-point one which looks like a double star.
Re 3/8" vs. 1/2", 3/8" nicer to use but agree that unless you buy a top quality 3/8" drive (like SnapOn) then you're best with a 1/2" one for heavier use with wheel bolts.
beauphoto
Post by beauphoto » Tue Aug 26, 2008 9:37 pm
Draper also do a plastic covered socket that stops any wheel damage. Works really well.
dom888
Post by dom888 » Tue Aug 26, 2008 11:42 pm
blimey, i never realised how much there was to know... to save me searching, does any know THE definitive model/make to get?
Plodwyn
Post by Plodwyn » Wed Aug 27, 2008 5:45 pm
just ordered mine from draper tools come as a 3 socket set with internal and external nylon covering part number 59080 £41.59 inc p&p and vat. they also do a deeper socket set for £60 odd part number 40102
Ozrs4
Re: RE: Torque wrench for RS4
Post by Ozrs4 » Wed Aug 27, 2008 10:21 pm
For those is Aust, this is what I found for a reasonable price around $90AUD:
Kincrome Micrometer Torque Wrench 1/2". #MTW150F
• Manufactured from nickel chrome plated alloy, 1/2â€
RS4Molar
Post by RS4Molar » Thu Aug 28, 2008 9:10 am
[quote="Ozrs4"]For those is Aust, this is what I found for a reasonable price around $90AUD:
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
Users browsing this forum: Bing [Bot] and 123 guests
