Rain sensor and hence auto closing windows - possible?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
rjkflyer
Post by rjkflyer » Fri Aug 22, 2008 11:17 am
Have a B7 RS4, with rain sensor.
There seems to be a configuration (+04) under Channel 020 of Module 09 which should allow you to have auto closing of windows (and sunroof) when rain is sensed.
1. Is this correct?
2. Does it matter that i don't have a sunroof?
3. Given the default code is +02 (for rain sensing enabled), then the new code needs to be 6 (02 + 04)??
4. It won't take it - gives 'ERROR' when i try either 4 or 6.
5. Do i need to login to this controller (surely not?)
6. If so, what's the login...?
Sorry rather a lot of questions!
PetrolDave
RE: Rain sensor and hence auto closing windows - possible?
Post by PetrolDave » Fri Aug 22, 2008 1:52 pm
I've tried coding that - and even though it accepted the coding, it doesn't work (I have rain sensor and sunroof).
rjkflyer
Post by rjkflyer » Fri Aug 22, 2008 2:44 pm
Hmmm, thanks. Did you have to 'login' or did you just enter the code?
PetrolDave
Post by PetrolDave » Fri Aug 22, 2008 3:43 pm
Just entered the code.
rjkflyer
Post by rjkflyer » Fri Aug 22, 2008 6:19 pm
Thanks - so any experts able to help with
(a) why mine won't accept the code (maybe it's finger trouble so advice welcome..)
(b) why the functionality fails to work?
PetrolDave
Post by PetrolDave » Sat Aug 23, 2008 11:00 am
(a) Maybe because you don't have a sunroof?
(b) If you look at the coding for the Comfort System (46) it can be coded to make the sunroof open with the key or remote - neither of these work either. It's as if Audi sometimes include a coding but fail to implement to code!
rjkflyer
Post by rjkflyer » Fri Sep 19, 2008 4:30 pm
Spoken to Audi who asked me to get dealer to raise a 'DISS' - some sort of 'fault/enquiry report'.
Dealer advises that this setting can't be enabled. However, no real explanation aside a possibly rater weak excuse that you can't enable it as cars sold in the USA would raise too much litigation risk. Thought that was precisely why we had region encoding in the CAN BUS, but obviously i must be wrong...
Be really good to hear from an expert on this!
Sebastian
Post by Sebastian » Thu Sep 25, 2008 8:34 pm
Not supported by the B7 architecture.
Sebastian @ Ross-Tech.com
rjkflyer
Post by rjkflyer » Sat Sep 27, 2008 3:53 pm
Ah, thanks Sebastian. Glad to see someone actually knows what they're talking about!
Return to “DTC / VCDS”
