NORTH EAST owner needs help !!!. VAGCOM
I am about to fit an rns-e to my S4 avant & wondered if anyone around newcastle could lend me a vagcom lead,or even help me code it as I am totally useless at this stuff.I have got the adaptor lead (plug & play) & the lead for the cd unit,Any help gratefully accepted. I live in Cramlington
S4 avant nogaro blue '04' bog standard apart from LPG conversion & B7 milltek catback system (resonated)
- PetrolDave
RE: NORTH EAST owner needs help !!!. VAGCOM
Do you have the antenna adapter too? Unless you currently have a Symphony II+ you'll need that as well (the RNS-E, like the Symphony II+, uses a double Fakra connector for the antennas but the older Symphony II uses a single Fakra and a "normal" car radio connector).
I think I have the symphonyII,combined radio,CD & cassette player,I assume it's the OE for my 53 reg S4 ? I have the removal keys,so if it would help,I can remove the headunit & look ?
- PetrolDave
Re: RE: NORTH EAST owner needs help !!!. VAGCOM
No need to remove it - if it has a cassette player then it's a Symphony II.archboldm wrote:I think I have the symphonyII,combined radio,CD & cassette player,I assume it's the OE for my 53 reg S4 ? I have the removal keys,so if it would help,I can remove the headunit & look ?
So you do need the antenna adapter as well.
RE: Re: RE: NORTH EAST owner needs help !!!. VAGCOM
Thanks PetrolDave,I appreciate your help,is that what they call a diversity adaptor no 0108 ? If so it comes with the plug & play lead I bought ?so now another question.Is there a knack to removing the unit,I've inserted the keys,but cant get it to move !!
- PetrolDave
Re: RE: Re: RE: NORTH EAST owner needs help !!!. VAGCOM
Who is "they"?archboldm wrote:is that what they call a diversity adaptor no 0108 ?
It's a lead that has a normal car radio antenna socket on one end and a double Fakra plug on the other end.
What always works for me is to insert the 4 keys fully, then angle them slightly outwards to make sure the locking tabs are fully disengaged - top two and then bottom two - and pull firmly.archboldm wrote:Is there a knack to removing the unit,I've inserted the keys,but cant get it to move !!
If it still won't shift like that then remove the glovebox (it's only 5 or 6 screws), then you can put your hand behind the unit and push from behind while doing as above with the keys.
RE: Re: RE: Re: RE: NORTH EAST owner needs help !!!. VAGCOM
PetrolDave,you are a star,thanks for your help,will try that now.Still have the problem of setting it up with the VAG-COM if anyone from up here can help???
Users browsing this forum: No registered users and 43 guests
