FMIC Fitted!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
Re: RE: Re: RE: FMIC Fitted!
Post by h8cak » Tue Aug 05, 2008 5:56 pm
andybnwc wrote:I want one asap , you got it proper straight too bet that took loads of time and cursing . Top job
anyone any pics fitted with a RS4 bumper or replica rs4?
Mine will be behind a OEM Rs4 bumper. Ill get loads of pics while doing it. Think there is a bit more room behind the Rs4 Bumper ?
Wide Body S4
MilkybarKid
RE: Re: RE: Re: RE: FMIC Fitted!
Post by MilkybarKid » Fri Aug 22, 2008 9:51 pm
Nice work looks damn good.
Im going down the twin sides route but have to say this looks nuts.
Think ive got the same colour s4 as you, any idea what its called? (off topic but fk it :P)
loomx
Post by loomx » Fri Aug 22, 2008 10:02 pm
Ming Blue Pearl.
All is still going well with the intercooler :D. Remap is brilliant.
But today my car decided it would only run 5psi, but I turned the ignition off and on, and its back to normal, but vagcom has given me this code.
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 00088
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Readiness: 0000 0000
Any Ideas?
Audi S4.
RS4 Y-Pipe, K04ed, 440cc Injectors, Miltek Duel Exhaust, Miltek 100cell Downpipes, Uprated Fuel Pump, AP Racing 6 pots, RS4 rear brakes, FMIC, MRC Remap.
quattronutter
Post by quattronutter » Fri Aug 22, 2008 10:19 pm
boost leak or dodgy n75
Last edited by quattronutter on Fri Aug 22, 2008 10:21 pm, edited 1 time in total.
MilkybarKid
Post by MilkybarKid » Fri Aug 22, 2008 10:20 pm
cheers for that,
nope sorry mate couldnt tell you what that is :(
Bluebrakes
Post by Bluebrakes » Sat Aug 23, 2008 1:48 am
Could be down to many things...
Leak
Diverter Valves
N75
Sticky Actuator on turbo
MAF (Possibly, doubt it. You only just changed it and was fine)
I would check the following:
N75
Check connector and pins as they are prone to damage. You'll need to pull the rubber boot back to do this.
Could check the signal.
Look in vag-com to see when its playing up. Check block 115 to see pressure differences
A mullered N75.
DVs
Ideally you need a hand vacuum pump to check negative pressure on actuator input. You can even watch them work if you take it right off. ;-)
Leak
Even though it was probably good to go a few days ago. Always worth removing it from the equasion. So check it.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
loomx
Post by loomx » Sat Aug 23, 2008 4:00 pm
Pressure tested it, there was a tiny leak from the right hand Bi-Pipe (really high pitched whistle) but fixed that. at around 14psi there is a wierd buzzing noise (sort of sound like an air pump) coming from the photo graphed area.
Sound familiar to anyone??
Any ideas?
Audi S4.
Blue_Thunder
Post by Blue_Thunder » Sat Aug 23, 2008 5:18 pm
Could be your N75.
h8cak
Post by h8cak » Sat Aug 23, 2008 5:24 pm
N75, The one with the brown plug in the picture.
Wide Body S4
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Aug 23, 2008 6:12 pm
the green one way valve that connects to your F hose is not working correctly
http://www.MRCtuning.com
loomx
Post by loomx » Sun Aug 24, 2008 11:54 am
The buzzing felt like it was coming from either the green valve or the black solinoid valve. Whats the part code for the green valve? is it worth change the other green valve at the same time?
Audi S4.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Aug 24, 2008 11:56 am
the green one way leaks then air foces through the black solenoid(making hte buzz noise) and pressurises the fue tank!
Bluebrakes
Re: RE: Re: RE: Re: RE: FMIC Fitted!
Post by Bluebrakes » Sun Aug 24, 2008 2:24 pm
Doug_S2 wrote:the green one way leaks then air foces through the black solenoid(making hte buzz noise) and pressurises the fue tank!
Can't argue with the god. ;-)
Makes sense.
loomx
RE: Re: RE: Re: RE: Re: RE: FMIC Fitted!
Post by loomx » Mon Aug 25, 2008 5:56 pm
Changed both the green valves (the one not in the picture had gone) and boost pressure tested, all was okay, but just been out for a drive, and it was only making 5psi again, ignition off and on, and back to normal.
Got this fault again.
I assume that means along with my one way valves, my N75 is on its way out too.
Boost is held steady at full throttle and tails of a couple psi at the redline. But on around 1/4 throttle itll spool up to 15psi and the second it hits 15psi it drops 5si and holds steady at 10psi. and at about 1/2 throttle its the same but 20->15psi.
N75 or could it be anything else?
Audi S4.
MilkybarKid
Post by MilkybarKid » Fri Sep 26, 2008 7:14 pm
HI mate, can i possible borrow this image to get someone to photoshop in filled in side vents?
Going to see what it looks like with solid bumper a the sides, with the big central vent similar to your own.
Dont want to go cutting my bumper up first though!
Give me a shout let me know either way
You get your boost problem sorted?
Lewis
Users browsing this forum: No registered users and 201 guests
