Anyone had coil pack failure (yet)?
rjkflyer
Post by rjkflyer » Wed Aug 20, 2008 8:41 pm
Got the engine warning lamp on today and a quick check with Ross-Tech VCOS shows ECU number 2 reporting a random/multiple misfire and a specific misfire detected on cyl 4. Car running fine however.
Dealer confirms that it sounds like a coil pack - obv in process of failing or intermittent.
Wondered of experience of others? Only done 17k...
Ozrs4
RE: Anyone had coil pack failure (yet)?
Post by Ozrs4 » Thu Aug 21, 2008 10:30 am
You're lucky to get 17K! Mine failed even before I took delivery. The dealer rang when I was on my way to pick it up and said EPC light came on and diagnosed with coil pack failure. They changed all 8 before I took delivery.
2007 RS4 B7 - Phantom black saloon
PetrolDave
Post by PetrolDave » Thu Aug 21, 2008 10:48 am
I've done nearly 27K miles with no sign of coil pack failure.
P_G
Post by P_G » Thu Aug 21, 2008 1:26 pm
My car has done 3k miles and no CP failure.
rjkflyer
Post by rjkflyer » Thu Aug 21, 2008 9:05 pm
Talking to the Mobile tech (a good and new idea for my dealer - man comes to your car at home and fixes it where possible) doesn't seem to be a big issue with RS4. Seem to have been some revisions to coil packs so the later ones are pretty reliable.
To be fair, the VDCS indicated a once-off intermittent fault so replacement was precautionary but done under warranty.
P_G
Post by P_G » Thu Aug 21, 2008 9:17 pm
P_G wrote:My car has done 33k miles and no CP failure.
8zero8
Post by 8zero8 » Fri Aug 22, 2008 2:51 am
i've had 3 replaced, but you should check, there is an open recall for early 07's, fuel pressure sensor, my car was cutting out like a bad cp, same symptom, and having had 3 replaced, i assumed it'd be my fourth, but it was the fuel pressure sensor...ck your VIN at your shop for open campaigns...
rjkflyer
Post by rjkflyer » Fri Aug 22, 2008 7:12 am
That's interesting - i was aware that mine needed the low pressure fuel sensor recall (the tech confirmed that - it's an early '06) but didn't know it could be a possible cause of poor running which i guess might have tripped the ECU.
tartan_rob
Post by tartan_rob » Sun Aug 31, 2008 9:05 am
I had 1 fail and Audi changed all 8.
2017 Kawasaki Z1000
2014 RS6
2014 S1
rjkflyer
Post by rjkflyer » Thu Oct 30, 2008 4:16 pm
Hmmm, car in dealer for DRC repair (again) and they advised they had changed a coil pack as ECU indicated a Cylinder 4 misfire. EXACTLY same error as i started this thread with.
Bit odd to have same failure twice (although no actual misfire evident). Anyone else seen this? Must suggest something else perhaps? ANy ideas?
(Have posted details on VAG-COM forum)
ghoonk
Post by ghoonk » Thu Oct 30, 2008 6:21 pm
do you guys get EPC or any visible indicator with coil pack failure?
2006 Sprint Blue Audi RS4 : photography by lifegauge
rjkflyer
Post by rjkflyer » Thu Oct 30, 2008 8:48 pm
Yes, the little amber engine lamp comes on in the instrument cluster.
ghoonk
Post by ghoonk » Thu Oct 30, 2008 10:39 pm
Fair enough. So far, so good *knocks on wood*
Users browsing this forum: Google Adsense [Bot] and 383 guests
