My stereo turns it's self back on when I take the key out!!!
rAudiguy
Post by rAudiguy » Mon Aug 18, 2008 9:09 pm
Hi Guys,
Been away on holiday for a couple of weeks and so just jumped back in the motor this morning. Got to work and pulled the key out, as normal the stereo/MMI turned it's self off and bleeped to show disconection of the blue tooth. Then only a couple of seconds later the music came back on! I put the key in again, turn the ignition on and then off again but it still was on so just pushed the button to turn it off.
On my way home turned it on again and everything worked fine, listen to a bit of music on the SD card slot but again when I got home it did the same thing!!
Anyone else had this before? Any Ideas?? PetrolDave need your help mate!!!
cheers
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
pippyrips
RE: My stereo turns it
Post by pippyrips » Mon Aug 18, 2008 9:19 pm
Although i've come across other types of odd behavior from time to time i've never had this!
I'm guessing you haven't used vag-com etc since this started so coding etc should be the same? - its the only thing i can think of :?
Try running a scan with vagcom and see if it throws anything up.
rAudiguy
Post by rAudiguy » Mon Aug 18, 2008 9:25 pm
it did go in for DRC before I went away and in honesty i've only driven it 2 miles from the dealer until today but don't recall it doing it when I got back. Will pop down in the morning and get them to check it out I think.
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Norrs2
Post by Norrs2 » Tue Aug 19, 2008 10:38 am
There's a Ghost in your car that likes music??? :lol:
Seriously, could it be something to do with your Bluetooth installation??
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
PetrolDave
Post by PetrolDave » Tue Aug 19, 2008 11:20 am
Never heard anything like that before...
Sounds like the radio is turning itself on instead of off when it gets the "key removed" message over the CAN bus?
Thorny
Post by Thorny » Wed Aug 20, 2008 2:53 pm
Slightly o/t nut my stereo is always on when i start the car even when it was off when i turned it off - is that normal?
rAudiguy
Post by rAudiguy » Wed Aug 20, 2008 2:54 pm
mine did that too....
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
pippyrips
Post by pippyrips » Wed Aug 20, 2008 4:02 pm
Thorny wrote:Slightly o/t nut my stereo is always on when i start the car even when it was off when i turned it off - is that normal?
Mine does whatever it was doing when the key was removed last time - off or on
PetrolDave
Post by PetrolDave » Wed Aug 20, 2008 4:26 pm
pippyrips wrote:Mine does whatever it was doing when the key was removed last time - off or on
Same here - that's what they're supposed to do.
rAudiguy
Post by rAudiguy » Wed Aug 20, 2008 4:30 pm
Before I had this problem if I had turned the music down or muted it for what ever reason when I'd get back in it would always be on again, not very loud but loud enough. I know you can change the settings but like you guys say it would nice if it did what ever it what last left at.
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
PetrolDave
Post by PetrolDave » Wed Aug 20, 2008 5:41 pm
When you turn the iginition back on it does 2 things:
1) the radio goes back to the state it was when you turned the ignition off
2) the volume is reset to a "standard" level, so if you had muted it it will be back on, and if you were listening to it loud it will be quieter - that's just how Audi have decided to make it work
Thorny
Post by Thorny » Thu Aug 21, 2008 2:35 pm
ok - so anybody know how to fix mine? or is it a dealer job?
PetrolDave
Post by PetrolDave » Thu Aug 21, 2008 5:19 pm
Thorny wrote:ok - so anybody know how to fix mine? or is it a dealer job?
If you are still in warranty - then dealer job.
dom888
Post by dom888 » Thu Aug 21, 2008 9:40 pm
i had this problem years ago in a bmw and it turned out to be a faulty key. try using your spare key and see if it still does it - worth a try i guess?
Thorny
Post by Thorny » Fri Aug 22, 2008 9:13 am
great - will try that - thank you
Users browsing this forum: No registered users and 195 guests
