RS4 tyre wear, front vs rear
RS Owner
RE: Re: RE: Re: RE: RS4 tyre wear, front vs rear
Post by RS Owner » Mon Aug 18, 2008 8:11 pm
F38 R35 it's on the door pillar. Is there a reason to use different pressures?
There seems to be a pattern with the OE Pirrelli PZero wearing quicker than other tyres. Is this because they are stickier? I dont think so but I only have experience of P0's.
I needed to change 2 tyres due to a puncture else I would have gone for Michelin Pilot Sport 2 as there seems to be a consensus that they are better (than P0 at least).
Also I was told to make sure the fronts and rears were not more than about 3mm wear difference due to the permanent 4WD.
SR71
Post by SR71 » Mon Aug 18, 2008 8:41 pm
The reason for the different pressures is that most people running F1's are using a 275/30 profile tyre not a 255/35.
I think the F1 popularity came about as a result of this EVO test: http://www.tyrereviews.co.uk/Article/20 ... e-test.htm
Keeping rolling radius similarity improves the longevity of your diffs.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
P_G
Post by P_G » Tue Aug 19, 2008 11:13 am
It is interesting for me as when running 255/35 Conti's I was advised by my local dealer to run 39 front and 36 rear, on the 275/30's I am running 39 front and 38 rear so not a huge amount of difference between the two tyre sizes.
PetrolDave
Re: RE: Re: RE: Re: RE: RS4 tyre wear, front vs rear
Post by PetrolDave » Tue Aug 19, 2008 11:13 am
sham wrote:guys what tyre pressure are you guys running on the front and rears
(i use the ps2 ro1)
The values on the sticker on the drivers door shut - 38 front, 36 rear IIRC.
Users browsing this forum: No registered users and 362 guests
