Brake pad warning light
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Nodds
Post by Nodds » Sun Aug 17, 2008 8:19 am
A week or two back the brake pad warning light came on, as it was booked in for sevice the pads would be changed. However on inspection at the service the pads have plenty of life left in them.
The light didn't come on again for a while, but lights up every time i start the car.
Is this a common fault and any ideas where to look to fix it ?
Nodds
Nige_RS4
RE: Brake pad warning light
Post by Nige_RS4 » Sun Aug 17, 2008 9:29 am
Very common problem - more than likely its just a bit of dirt or moisture in the pad warning light connector under the front wheel arch
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
mikeyquattro
Post by mikeyquattro » Sun Aug 17, 2008 9:41 am
I had a broken wire on mine. PIA to find as vag-com doesn't say which sensor is playing up
Tomorrow is another day
Nige_RS4
Post by Nige_RS4 » Sun Aug 17, 2008 11:21 am
Well S4's only have pad sensors on the front, so shouldn't be too difficult to trace.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Nodds
Post by Nodds » Mon Aug 18, 2008 10:19 pm
i have tried cleaning up the connectors, but no change. So i guess its a broken wire.
How do they work, is there a charge running through the circuit and when the loop is broken ususally by the pads wearing down the circuit is broken and the warning light comes on. So a broken wire would give the same result ?
If its not an easy fix can you ust disconnect them ?
Nodds
SJS
Post by SJS » Tue Aug 19, 2008 12:29 pm
have you tried sticking a short length of wire into the connector to see if the light goes out. that proves whether there is a fault in the cable going to the back of the caliper. If not then its likely the connection on/in the pad has become open circuit.
Nogaro S4 Yr2000. MRC remap, K04s, Milltek
Users browsing this forum: No registered users and 70 guests
