Cruise control packed up ??
g338iry
Post by g338iry » Mon Aug 11, 2008 7:26 am
Anyone had any probs with cruise ? Checked fuse all good.
GardinerG
RE: Cruise control packed up ??
Post by GardinerG » Mon Aug 11, 2008 1:15 pm
Hi g338iry, I would find someone local to run a full fault scan with VAG-COM or similar.
Where are you based?
andyt
Post by andyt » Mon Aug 11, 2008 6:14 pm
I had a problem with the CC on my S4. It would entirely stop working until I pulled over, stopped the car, took the key out and then started it again (which was a PITA on the M62 :shock: :wink:). It turned out to be a fault with the controller stalk whereby if I pushed the speed+ button anything more than gently it would trigger an implausible signal and cancel the CC. This showed up in a vag-com scan IIRC. In the end I just learned to live with it!
estrop77
Post by estrop77 » Sat Aug 16, 2008 11:56 pm
mine used to stop working if I used my indicators. cruise stalk replaced under warranty by Camberley Audi. all sorted.
Rich
RS6 Saloon - 03 Mugello Blue / Silver. Fully loaded. Standard and mint used at weekends only.
Users browsing this forum: No registered users and 70 guests
