Remote key fob weak signal
My remote has always been weak and even after changing batteries its the same , you got to be really close for it to work. Is there anyway to fix this ?
jimbo1234567
- 5th Gear
RE: Remote key fob weak signal
if you remove the blue interior light and replace it with a white one the central locking should work loads better . HTH
665 bhp + 586 lbft...
Bluebrakes
There is a mod to fix this too. Or rather extend the range of the system.
There is a wire that hangs down in the rear bumper area that is infact the aerial for the remote key.
Extend this aerial by grabbing some wire from Halfrauds or maplin and extending it behind the rear bumper.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
Re: RE: Remote key fob weak signal
jimbo1234567 wrote:if you remove the blue interior light and replace it with a white one the central locking should work loads better . HTH![]()
How did you know it was blue?
RE: Re: RE: Remote key fob weak signal
where about is the aerial in the bumper area ?
