Looking at some new wheels - info required about wheels
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
arS4
Post by arS4 » Thu Aug 07, 2008 8:07 pm
Looking at some wheels -
Metal Type: Aluminium
Tyre Type: All-Weather
Rim Width: 8.5J
Tyre Width: 255
Rim Diameter: 19 inches
Aspect Ratio: 35
Offset: 48
Load Index: 96
Number of Studs: 5
Speed Rating: Y: max 186 mph
Will these fit my B5 S4?
Dan :)
The art of diplomacy - telling someone to "Fcuk off" so that they actually look forward to the journey
si_hill
RE: Looking at some new wheels - info required about wheels
Post by si_hill » Thu Aug 07, 2008 9:46 pm
You will need to know the stud pattern. S4 is 5x112.
Tyres will not fit, 235 is about the widest you can go on the S4.
Offset is high which will probably mean that you will require spacers to push the wheels out so ithey dont foul the suspension and with a 8.5J rim they may sit proud of the arch which will be an MOT failure. You should be looking for an offset of ET30-ET35 for an 8.5J rim
h8cak
Post by h8cak » Thu Aug 07, 2008 10:49 pm
Best u can do on tyre size for a b5 s4 is 235/35/19. Et 35 and 5 x 112 stud pattern
Wide Body S4
AdamS4
Re: RE: Looking at some new wheels - info required about whe
Post by AdamS4 » Fri Aug 08, 2008 7:12 am
h8cak wrote:Best u can do on tyre size for a b5 s4 is 235/35/19. Et 35 and 5 x 112 stud pattern
Exactly what i'm running. Running 5mm wheel spacers on the front tho due to brake caliper clearence
Users browsing this forum: Majestic-12 [Bot] and 39 guests
