Sat Nav retro-fit
2.7 V6 30v biturbo - 380 bhp
jmn
Sat Nav retro-fit
Post by jmn » Wed Aug 06, 2008 9:36 pm
Has anyone retro-fitted the sat nav unit to an RS4? Can you get up to date mapping?
Is the wiring already present?
Would it be better to fit a unit from a later A4?
Any recommendations as to who could do this in SW England?
Presumably the TV function which is, I think, analogue will cease to function with the advent of digital TV and the switching off of analogue transmissions?
mbelle
RE: Sat Nav retro-fit
Post by mbelle » Thu Aug 07, 2008 7:49 am
There's no point retro-fitting the factory Sat Nav of the B5 RS4 i.e. CD-based Sat Nav (RNS-D), as this is dated, 2007 version maps are the last maps to be released for this unit (as advised by Audi) and as you stated, the analogue TV will probably cease to work.
RNS-E which is the DVD-based Sat Nav is the way forward. Although if you are thinking of doing this, you'd need a unit from an A6 IIRC (there is a thread regarding this, with instructions and requirements in order to fit it).
This unit comes with digital TV as well I believe...
Marcus
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Aug 07, 2008 6:38 pm
Yep as said, the RNS-E unit is the one to go for
You need a A6 (4B) RNS-E unit, a GPS antenna, adapter wiring. Then you need to do some CAN wiring, and also some coding via VAG-COM or equivalent. Also you might find you don't like the way the unit fits, as it has a few mm gap on each side. Bottom needs to be chopped off slightly.
Digital TV tuner is not built into the unit, but can easily be done. Depending on if your car has a OEM TV Tuner, then you could go the new hybrid option from the latter Audi's, or if you haven't then go aftermarket, i.e. Alpine
Virdee Autos ~ 07950-526592
JDB
Post by JDB » Thu Aug 07, 2008 7:56 pm
WHat link ENS-E with an ALpine TV turner
JDB
sorry should say RNS - E
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Aug 07, 2008 9:12 pm
I used a multimedia adapter, which you can buy from Kufatec and the likes.
This uses the 32pin grey connector on the rear of the unit, and gives you AV inputs.
Then all you do is, use a IR remote eye connected to the Alpine TV Tuner, to control it, or alternatively buy the more expensive adapters which alow you to control it from the RNS-E, but not entirely sure if they work with the Alpine tuner.
I just finished my setup last week, and so far results are impressive!
HTH
Brooner
Post by Brooner » Fri Aug 08, 2008 5:14 am
This is the man to talk to top man and very help full done a few on here i belive
http://www.tclsatnav.com/
