New Wheels
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Alex123
New Wheels
Post by Alex123 » Wed Jul 09, 2008 8:29 pm
Hi Guys,
Just looking at some RS4 reps but not sure if they will fit. Details are -
Rim Width: 8J
Offset: 33
They're 18" with 235/40 tyres. I've done some searching but can't find any reference to a ET33 ofset. Will they fit ok?
Many Thanks
h8cak
RE: New Wheels
Post by h8cak » Wed Jul 09, 2008 8:53 pm
Best for our cars is et35
Wide Body S4
jimbo1234567
RE: New Wheels
Post by jimbo1234567 » Wed Jul 09, 2008 10:06 pm
looks like your 2mm out alex! be reet
Alex123
Post by Alex123 » Wed Jul 09, 2008 10:32 pm
Dam Shame! Oh will have to keep looking! If anyone knows if a decent set of early RS4 reps let me know!!
jimbo1234567
Post by jimbo1234567 » Wed Jul 09, 2008 11:28 pm
only joking bud 2mm is feck all :jump_clap:
MilkybarKid
Post by MilkybarKid » Fri Jul 11, 2008 9:27 am
ive got 2 spacers if you end up needing them for clearance pm me if you need em
Alex123
Post by Alex123 » Mon Aug 04, 2008 10:24 am
Thanks MilkybarKid. I ended up buying a different set in the end with a 35 offset. However, i went to fit them this weekend and found that they don't clear the front calipers! Doh!!!
After speaking to the company that supplied them, it turns out that I have a very rare brake caliper which is slightly larger than standard. He's going to send out some spaces so that should do the trick.
Not really sure what the deal is with the calipers though. They look pretty standard and are made by Lucas. The car is one of the mid face lifts so i guess thats probably why.
frazered
Post by frazered » Mon Aug 04, 2008 2:04 pm
Alex,
would be interested in the pn for that caliper as I am about to fit wheels in the same size and have a facelift car
Alex123
Post by Alex123 » Mon Aug 04, 2008 2:14 pm
I actually took a pic when i had the wheel off. If it'll help, PM me ur e-mail address and i'll send it over. I'll post the PN on here next weekend when i have the wheel off again.
curtis11
Post by curtis11 » Mon Aug 04, 2008 6:43 pm
none of the rs4 b5 reps clear the caliper on the s4, and if you have new brake pads forget about it. i had to use a 5mm spacer and a bit of the old angle grinder to get mine to clear with new discs and pads.
Bluebrakes
Post by Bluebrakes » Mon Aug 04, 2008 8:15 pm
curtis11 wrote:none of the rs4 b5 reps clear the caliper on the s4, and if you have new brake pads forget about it. i had to use a 5mm spacer and a bit of the old angle grinder to get mine to clear with new discs and pads.
Ah man. Those are the wheels i wanted to get. :(
So these are made by replica? 18"?
So no chance getting them over RS4 callipers and discs then? let alone standard s4.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
curtis11
Post by curtis11 » Mon Aug 04, 2008 8:57 pm
dont know the make but they are 18s , you might be ok on rs4 calipers, i think they have better clearance but not sure.
Bluebrakes
Post by Bluebrakes » Mon Aug 04, 2008 10:06 pm
So what you are saying then is its the front of the calliper clearance opposed to the internal circumference of the alloy?
curtis11
Post by curtis11 » Mon Aug 04, 2008 10:34 pm
yea the front of the caliper is the problem, the internal diameter of the wheel has plenty of room
h8cak
Post by h8cak » Mon Aug 04, 2008 11:58 pm
Just space them or get a different ET .
Wide Body S4
Users browsing this forum: Majestic-12 [Bot] and 60 guests
