Rs4 won`t start after turbo replacement
2.7 V6 30v biturbo - 380 bhp
Rs4-Digitec
Re: RE: Re: RE: Re: RE: Rs4 won`t start after turbo replacem
Post by Rs4-Digitec » Thu Jul 31, 2008 10:10 pm
Stigter wrote:B7 rs4 brakes - very nice. Good luck getting to the bottom of this and keep the forum posted. ;-)
Will do.. The brakes are rs6 8pot with 365mm discs.
Stigter
RE: Re: RE: Re: RE: Re: RE: Rs4 won`t start after turbo repl
Post by Stigter » Thu Jul 31, 2008 10:15 pm
My bad. Just saw the rs4 discs. Didn't check for the brace on the outer side of the caliper - lol
Rs4-Digitec
Re: RE: Re: RE: Re: RE: Re: RE: Rs4 won`t start after turbo
Post by Rs4-Digitec » Thu Jul 31, 2008 10:21 pm
Stigter wrote:My bad. Just saw the rs4 discs. Didn't check for the brace on the outer side of the caliper - lol
:D No problem
mbelle
RE: Re: RE: Re: RE: Re: RE: Re: RE: Rs4 won`t start after tu
Post by mbelle » Fri Aug 01, 2008 9:40 am
Can I ask how long it took you to replace them yourself, in total?
Marcus
Current: A C6 Audi
Previous: A B5 Audi
dummi
RE: Re: RE: Re: RE: Rs4 won`t start after turbo replacement
Post by dummi » Fri Aug 01, 2008 12:03 pm
ignition module on the top of the airbox?
musty1
Post by musty1 » Fri Aug 01, 2008 12:11 pm
dummi wrote:ignition module on the top of the airbox?
Would still start but would run poor, have you checked all your hall senders and tensioners all so like quattronutter check the earth's are you getting the ecu light on the clocks when ingition is on?
1.9TDI A6 are sh*t wrong forum
Rs4-Digitec
Post by Rs4-Digitec » Fri Aug 01, 2008 12:37 pm
Have been checking some today,and seems that when i turn the ignition on there is no power to either the fuel pump or ecu.
I measured 0v on the fuel pump and ecu fuses aswell..
It took me about 5hours to remove the engine 2 hours to replace the turbos and about 5 hours to mont the engine back in.
And now an endless amount of hours seaching for the fault..
Rs4-Digitec
Post by Rs4-Digitec » Tue Aug 12, 2008 8:51 pm
I found the problem after some research. Some how the ecu has got some moist inside so it did not work. Sendt it to a company that fixes ecu`s and it it now fixed and hopefully installed tomorrow... 3months without my rs4 is quite boring :)
Users browsing this forum: No registered users and 176 guests
