Water deflectors
Water deflectors
When I got the car there was a water deflector cable tied to the front wishbones. They fill the gap where the front driveshaft enters the wheel arch area. I have learned they were not fitted at the factory - fitted during PDI. Mine started fouling the wheel the other day so got underneath and had a proper look. Has everyone still got these fitted? and are they cable tied in place? CHeers.
RE: Water deflectors
Its an air deflector to cool the brakes. Its on all cars secured by rivet at one end and clip at the other. It can act as a water deflector if you hit surface water at speed. Blind bend at 60mph IIRC. The plastic inner clip dislodged at one end after soaking the clutch plates & seizing them. Thankfully they unseized with a jolt !!!!!!
RS2 'an estate car named Desire'
Deflectors
Thanks for the responses.
They sound like a bit of an afterthought.
Will have a go at securing them with bigger cable ties later.
