engine cut out at 6500
hungryhorses
why doe s my engine on RS4 cut out/ lose power at 6500 RPM
also the emission indicator is yellow and EPS light is yellow.
RE: engine cut out at 6500
Your EPC is lit, which means the ECU has detected something wrong in the engine system. As such, your car is probably running in a form of limp mode to prevent you from damaging the car further through hard driving, e.g. taking the engine up to high revs.
As per your owners manual, you should take your car immediately to your dealer and not drive it hard until you do so. They will be able to diagnose the problem and try to fix it, assuming you haven't already caused more damage by driving the engine hard while the warning lights are on.
2006 Sprint Blue Audi RS4 : photography by lifegauge
- PetrolDave
If you have VAG-COM then take a look at what fault codes the engine ECUs (there's two - address 1 and address 11) have logged.
hungryhorses
hungryhorses
exhaust manifold
having just bought my RS4 of independent dealer, the EPC light comes on soon after.
Rac(audi assist) run diagnostic says manifold valve was able to disable light safe to drive.... makes you wonder!
Audi Dealer says new intake manifold- to take 4-5 days!
Stress.... Agggghhhhhh!!!! dealer must have known this... any come back?
under warranty though cant wait to hit 8000rpm.
- PetrolDave
Re: exhaust manifold
If you can get someone independent to say, in writing, that the car must have had this fault when the dealer sold it to you then you have a cast iron case.hungryhorses wrote:dealer must have known this... any come back?
Had same problem. Dealer cleaned the intake manifold runner flaps or something and I've not had the EPC come up on me for over a month. However, with enough concern expressed on my part, they're replacing the entire intake manifold system under warranty.hungryhorses wrote:having just bought my RS4 of independent dealer, the EPC light comes on soon after.
Car is going in tomorrow and will be in for 2 to 3 days, after which my warranty ends, and I'm on my own.
Users browsing this forum: Bing [Bot] and 723 guests
