OMORI boost Guage Fitting.
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
h8cak
Post by h8cak » Fri Jul 18, 2008 10:49 pm
As above need some fitting instructions or some pointers on where the wires and pipes go?
Wide Body S4
Stigter
RE: OMORI boost Guage Fitting.
Post by Stigter » Fri Jul 18, 2008 11:09 pm
Really hard to fully explain but here goes.
OK, so. parts you have are
1 .Gauge
2 .Boost sending unit thing with wire and connector.
3 .Wiring harness and bare wires to hook up power and illumination.
Step one: Right so, First have a look at the firewall at the back of the engine and you will see a allen key bolt. Well I used this to hold the (2) so attach this now
Step two: T into the pipe from the fuel pressure regulator to the inlet manifold and joint to the sensor we fitted in step one. (although some people will tell you its very bad to do this so its your call - worked for me but its to do with problems that may occur if pipe falls off)
Step three: get wire from (2) into foot well. (I had it going through the gromit into the ECU weather box and then down and into the car)
Mount the gauge where you want it and get the connection to it from (2)
Then its just a case of getting power to it from item (3) this is where the instructions would be nice but sure someone can confirm, might help if you identify what colours you have on this. It started to rain and the little bit of paper with the wiring got messed up.
Sure Blue thunder will know.
frazered
Post by frazered » Sat Jul 19, 2008 9:43 am
http://www.audiworld.com/tech/int.html
audiworld tech article for an omori 60mm
Blue_Thunder
Post by Blue_Thunder » Sat Jul 19, 2008 11:00 am
dr_wimpkins
Post by dr_wimpkins » Thu Jul 24, 2008 2:35 pm
I can help out if needbe Carl.
All BLOW and no GO.........
h8cak
Post by h8cak » Thu Jul 24, 2008 4:30 pm
I sent u a txt. Cheers Pat
Wide Body S4
AdamS4
Post by AdamS4 » Thu Jul 24, 2008 9:59 pm
I used the AWE guide
h8cak
Re: RE: OMORI boost Guage Fitting.
Post by h8cak » Sat Jul 26, 2008 1:02 pm
AdamS4 wrote:I used the AWE guide
Link ?
Wide Body S4
Blue_Thunder
Post by Blue_Thunder » Sun Jul 27, 2008 1:22 pm
Link ?
If you look at the thread I posted, it has the link, as well as some more info.
Also, as I fitted Stigter's with him, you should find that the wires are all long enough now to allow an easy fitment. Good luck!
h8cak
RE: Re: RE: OMORI boost Guage Fitting.
Post by h8cak » Wed Jul 30, 2008 9:30 pm
Now fitted. pice of p*ss. 45mins all in. Found that the cable was not long enough for a nice tidy install so i had to extend it. Apart from that im well happy. Much better than my old guage. Just need to resist the power to dim the back light slightly.
Wide Body S4
travs
Re: RE: Re: RE: OMORI boost Guage Fitting.
Post by travs » Fri Aug 01, 2008 12:51 pm
h8cak wrote:Just need to resist the power to dim the back light slightly.
My continuous night-time driving retina-burn means I should do that also.
Is that all that needs to be done? In-line resistor on the feed? Would you be any good at suggesting a suitable rating? I'd have no idea.....
Written-off: Night Blue Metallic S6 5.2 V10 - Private plate, LED interior kit.
Sold:
Hibiscus Red Metallic S4 (B5 99.5) w/AmD Stage 1 Remap, RS4 Exhaust w/ Gutted Precats & R32 Tailpipes, Afterun Sensor, H&R Coilovers
h8cak
RE: Re: RE: Re: RE: OMORI boost Guage Fitting.
Post by h8cak » Sat Aug 02, 2008 6:07 pm
Nor do i. Ill prob ask and buy a few and see which one is the best. Ill let u know as ill be doing it mon/tues.
Wide Body S4
Users browsing this forum: No registered users and 131 guests
