Audi RS4 Upgrade Intercooler Kit from Wagner Tuning
2.7 V6 30v biturbo - 380 bhp
Justin:NorCal
Post by Justin:NorCal » Sat Jul 19, 2008 12:34 am
Will these fit on an S4 with RS4 bumper?
rs-werkstatt
Post by rs-werkstatt » Sat Jul 19, 2008 7:35 am
Justin:NorCal wrote:Will these fit on an S4 with RS4 bumper?
I heared, that in the next days a customer with the same question as yours, will go to Lupo911 an they will check if that works.
blackb1ade
Post by blackb1ade » Sat Jul 19, 2008 9:55 am
Nice :-)
Don't suppose you have a pic of these on an RS4 WITH the front end etc all back on and tidied up do you?
I prefer the completely 'stock' look is why I'm asking - I dont mind foregoing the foglamps (as I've never ever used them anyway) but I do want to retain front grilles - I'd just like to see how you've done it, so to speak.
If that's possible of course - cheers
Avus B5 RS4 with St.3 MTM
rs4boy
Post by rs4boy » Mon Aug 18, 2008 7:14 pm
Has anyone on here had them fitted yet if so what do you think about them
Jason
Durit
Post by Durit » Fri Aug 22, 2008 12:19 pm
please, can you tell me if there is absolut need to remap the car after installing your IC
i have MTM 460 remap (stock turbo, milltek 200 cat) and i wonder if i can mount these IC without remaping the car: will i get same power with less "stress" for turbos?
Less pressure drop, less work for turbo to obtain the same intake P?
RS4 mtm 460 "safety car", Milltek, Koni, Mov'it 6/380-4/322, teamDynamics wheels ------- S6 plus, mtm, H&R, Koni
I'm french (nobody's perfect) sorry for my bad English!
okkim
Post by okkim » Fri Aug 22, 2008 2:19 pm
No, you don't need to remap it.
blackmolley
Post by blackmolley » Thu Sep 25, 2008 3:53 pm
I think if you want to get the best out of the aftermarket intercoolers you NEED to re-map.
Fact is that - besides lesser pressure drop - the intake temperature is way lower than with OEM intercoolers as we all can see on the graphs (btw .. this is not only due to bigger/better intercoolers ... the airducts are bigger as well ...) .This enables the 'map-guys' to enhance the mapping by means of enhacing ignition (lower temperatures means lesser change of detonation).
I swapped an OEM frontmount intercooler on my ex-EVO VI with a bigger one (more volume/lesser pressure drop, and a remap had to be done to use the advantages in full. Offcourse you'll be fine without a remap but you won't get the max. out of your car and that's what we're all here for aren't we? .....
Nige_RS4
Post by Nige_RS4 » Thu Sep 25, 2008 5:24 pm
You don't need a remap to increase ignition timing on Audis, it can be done with vag-com (but you need to make sure your car can run increased timing in the first place)
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Durit
Post by Durit » Fri Sep 26, 2008 8:31 am
hi
thank you for the answears...
lower intake temp and less pressure drop means less stress for the K04... and that is enough for me.
but i've noticed that the lower is the outside temp, the lower is my boost pressure (higher air density means more power)
then, if i get Wagners without remaping, the boost pressure will be lower too (to compensate the intake temp) or not?
if not, that mean more power (same boost with higher density)
IGO300
Post by IGO300 » Fri Sep 26, 2008 11:14 am
Nige_RS4 wrote:You don't need a remap to increase ignition timing on Audis, it can be done with vag-com (but you need to make sure your car can run increased timing in the first place)
How do you do this on vag-com
Nige_RS4
Post by Nige_RS4 » Fri Sep 26, 2008 12:12 pm
You need the engine login code from your tuner.
If you don't have this, then it's a non-starter.
It's also helpful if your tuner has increased the retardation range, as the std map will only <beep> a certain amoutn if it detects a bad batch of fuel / problem etc...
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Lupo911
Post by Lupo911 » Thu Dec 11, 2008 6:09 pm
Wagner Tuning is offering a 10% Discount on all our Parts ... Offer is valid till 31.12.2008.
Now it should be the rigth Time to get the good Stuff...
http://www.wagner-tuning.de/tuning.php
for English
http://translate.google.de/translate?u= ... e&ie=UTF-8
Users browsing this forum: Bing [Bot] and 75 guests
