FATS results
2.7 V6 30v biturbo - 380 bhp
Jonmurgie
FATS results
Post by Jonmurgie » Sun Jul 13, 2008 10:39 am
Have been reading up about the common issue of MAF problems on the RS4 and yesterday had the chance to log some details on an car I went to look at with the view to purchasing. However, amongst other concerns I'd appreciate some feedback on the following FATS log:
TIME - RPM - MAF - TPS - IGN
32.85 - 3080 - 112.97 - 92.5 - 18.8
33.68 - 3520 - 121.78 - 100 - 17.3
34.51 - 3920 - 133.31 - 100 - 19.5
35.35 - 4360 - 149.69 - 100 - 24.0
36.20 - 4760 - 163.00 - 100 - 21.0
36.98 - 5120 - 180.81 - 100 - 20.3
37.78 - 5480 - 182.08 - 100 - 15.0
38.59 - 5800 - 195.69 - 100 - 18.0
39.32 - 6080 - 208.56 - 100 - 15.8
40.20 - 6360 - 217.72 - 100 - 18.0
40.95 - 6640 - 227.22 - 100 - 14.3
41.71 - 6880 - 234.22 - 100 - 15.0
Plugged all that into here http://nyet.org/fats/?image=jonmurgie1 and it came back with a figure of 5.48... Don't know how it works the HP out though as it doesn't know what the car was?!!
Reading up on the forum it would seem that the MAF figures are very low, is that so and does that mean they are on their way out? Seems that the figure for a standard RS4 should be nearer 280, or am I wildly wrong?
The following is the log from block 115, which looks like steady standard boost:
TIME - RMP - LOAD - SPEC - MBAR
33.27 - 3320 - 124.1 - 1780 - 1900
34.06 - 3720 - 115.8 - 1740 - 1760
34.98 - 4160 - 115.8 - 1740 - 1760
35.78 - 4560 - 118.0 - 1760 - 1770
36.63 - 4960 - 116.5 - 1760 - 1770
37.41 - 5320 - 112.0 - 1830 - 1770
38.23 - 5640 - 115.8 - 1830 - 1820
38.96 - 5960 - 116.5 - 1810 - 1850
39.82 - 6240 - 115.0 - 1830 - 1840
40.58 - 6520 - 116.5 - 1880 - 1850
41.33 - 6800 - 115.8 - 1860 - 1900
42.08 - 6520 - 11.30 - 990 - 1870
So, thoughts on this one... problems or nothing to worry about?
Can anyone give me the expected peak MAF figure for a healthy standard RS4?
Jon
Doug_S2
Trader (Expired)
RE: FATS results
Post by Doug_S2 » Sun Jul 13, 2008 8:22 pm
fecked maf - and running slightly lower boost top end than a stock car should.
http://www.MRCtuning.com
Jonmurgie
RE: FATS results
Post by Jonmurgie » Mon Jul 14, 2008 9:11 am
Thanks for confirming my suspicions... what is a good MAF figure to expect for a standard car then?
Nige_RS4
RE: FATS results
Post by Nige_RS4 » Mon Jul 14, 2008 9:39 am
280-290 g/s is standard IIRC. Looks like that car is pushing out just over 300bhp!
That car may also have shot bypass valves or a small leak which may be the cause of the slight drop in peak boost.
Is it enough to put me off buying it?? It's a difficult question, as the parts may have only just failed. I would imagine that you would want to negotiate at least £250 off the ticket price to cover the cost of the above parts + a boost leak/health check.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Jonmurgie
RE: FATS results
Post by Jonmurgie » Mon Jul 14, 2008 10:10 am
Thanks Nige, this was the Noggy blue one up in Warwick... really nice seller who was fascinated by the VAG-COM and only too happy for us to go play! Given the above and a few other factors with the car I think I'm going to give it a miss!
steffos
FATS results
Post by steffos » Mon Jul 14, 2008 10:12 am
Jon, thanks for that info. Is there any firm close (ish) to me in Warwick that can sort this? Are MRC down in Banbury?
Jonmurgie
RE: FATS results
Post by Jonmurgie » Mon Jul 14, 2008 10:13 am
Steven, I'll drop you an email for a chat :)
ollys
RE: FATS results
Post by ollys » Mon Jul 14, 2008 2:05 pm
Forgive my ignorance, but could some one kindly explain what the accronym (I assume) FATS stands for?
thanks
rickoshea
Post by rickoshea » Mon Jul 14, 2008 8:04 pm
Fecked And Totally Shot :)
Jonmurgie
Post by Jonmurgie » Mon Jul 14, 2008 10:57 pm
Ha, not quite though it's probably mostly true!! This the the meaning it would appear:
FATS is an acronym for "For the Advancement of The S4"
