Will anything happen to the oil pump inside the gearbox? Is there another route inside the box for the oil to flow around?
I hate cars..... One thing after another...
Can anyone tell me the impact of disconnecting the gearbox oilcooler pipes and putting blanking plugs in place short term? Obviously the gearbox oil won't get cooled, but that is better than it leaking all over the place
S4 - no longer missing 1 engine. Last seen leaving trailing black lines of gearbox oil.
Re: I hate cars..... One thing after another...
To prevent any possible damage, just go to any hydraulic hose place and get a link pipe to join the 2 together.spen wrote:Can anyone tell me the impact of disconnecting the gearbox oilcooler pipes and putting blanking plugs in place short term? Obviously the gearbox oil won't get cooled, but that is better than it leaking all over the place![]()
Cost..........£10?
RE: Re: I hate cars..... One thing after another...
I'm not running a gearbox cooler not had a problem so far
1.9TDI A6 are sh*t wrong forum
a6's don't have one and are ok, safe bet is trig's pipe solution
My S2 runs an s4 box with the ports linked together.
http://www.MRCtuning.com
The b7 box has blanks on them , no oil cooler .
Unit 20
0151 3366888
0151 3366888
I'm not saying they're not needed. I suspect it's to warm the oil up to reduce drag in the gearbox as well as cool it down should it get hotter than the water.
For my requirements, today, which involves a leaking pipe, blanking the feeds is the best option.
However, the stealer was singularly unhelpful this morning. I don't own a b7 S4 so he can't find the plugs for me cos the computer won't tell him.
WOW. Camberley Audi called me back! The thread on the banjo bolts is M16x1.5.
VAG blanking plugs are £4.62.
Speedflow M16x1.5 blanking plugs are a bit cheaper - http://www.speedflowshop.co.uk/m16-x-15 ... -850-p.asp
Re: RE: Re: I hate cars..... One thing after another...
but musty A6 is running rs4 box.dummi wrote:a6's don't have one and are ok, safe bet is trig's pipe solution
in my car all i have done is cut the pipes and looped them back connect them together with some high pressure rubber hose you can see it coming in under the gearbox mount
alex
electric van for work
a4 v6 3.0 vortex sports for her
sold B5 passat 2.7T rs4/rs6 hybrid 477.17 bhp/471.98 lbs (483ps/640nm)
ZX9R sold replaced by hayabusa just because
Corrado vr6 turbo for fun
RE: Re: RE: Re: I hate cars..... One thing after another...
AHHHHHHHHHHHH I see the engine is out lets put some ko4's on lol
Right I now have blanking plugs. I can take the leaking pipe off and quickly bung the gearbox. Then I can either loop the pipes together with a bit of hose as suggested, or I can leave the blankinig plugs in and see what happens. I think it'll be fine. No one in their right mind would design a 'box which used a pump with an external pipe as the only vent for the pressure. I hope....
what I really want to know is how Alex got my engine crane out of my garage without me knowing....
Users browsing this forum: Majestic-12 [Bot] and 48 guests
