TIAL 650 GT28R KIT PRELIMINARY RESULTS: 530WHP AT 24PSI
addictmotorsport
We expect over 550whp easy on this set up (should do 575whp). The final tune will be 32 taper to 28 psi.
This kit bolts on to stock manifolds, which is what produced these numbers.
http://forums.audiworld.com/s4/msgs/2824633.phtml
RE: TIAL 650 GT28R KIT PRELIMINARY RESULTS: 530WHP AT 24PSI
22psi boost and it is a 650bhp car?
What is the spec of the car?
http://www.MRCtuning.com
looks more like absolute on that test with the dyno chart
it says below 28psi spike to 23.4 at red, 22psi requested?
Man, whats going on with all these crazy bolt on kits producing huge numbers with no internals ? Gotta be BS or close to popping ?
From their site:
Test car specs :
TiAL 650 Kit
EPL/AMD TiAl Base File
Sportec IC's (made for the RS4)
Sportec dual 2.5" no cats
RS4 Heads Complete
RS4 Intake Manifold and TB
RS4 Bi-Pipe and Y-Pipe
Saenz Rods (Pauter)
Stock Pistons and Headgasket
Stock Airbox with Stock Filter
Aquamist HFS-1 w/ Dual .8mm Jets runing 50/50 METH
EPL 85mm MAF
60lb Injectors
BOOST: SPIKE TO 28 TAPER TO 23.8 AT HP PEAK
Test car specs :
TiAL 650 Kit
RS4 Heads Complete
Saenz Rods (Pauter)
EPL 85mm MAF
60lb Injectors
addictmotorsport
The boost graph is simply to illustrate the boost onset and response of the new TiAL turbo kit. Obviously because the stock sensor is maxed at 22psi you can't use that for boost profile any longer. The kit utilizes a GT28R CHRA with custom cast turbine housing and custom billet compressor wheel. Kit comes complete ready to bolt on to stock manifold. As stated above this car has a built engine, though it's producing low enough torque (450lb.ft to wheels) that it may not be an issue.
These turbo's are designed to spool faster then RS6's and flow about 75hp more air up top. 20psi is achieved by 3500rpm in 4th gear and 3800rpm in 3rd. This kit has been in development for over 3 years, and thanks for letting me post up some information on this forum. I assume that you guys would be interested in this kit, and it should be available from select TiAL dealers in Europe.
Here is another link to the AZ thread with some more info:
http://www.audizine.com/forum/showthread.php?t=221617
Jason Petek
Addict Motorsport Design
PNW, USA
PNW, USA
Questions, questions, questions
Will these bolt on to B5 RS4.
What BHP will a stock engine go to safely without upgrading rods etc.
Is there a need for water/meth. If so at what BHP level
addictmotorsport
RE: Questions, questions, questions
These directly bolt on to both versions of the 2.7 biturbo. The kit comes with all hardware including inlet pipes. I have seen 600whp without rod failure and 450whp with rod failure. Torque is what kills rods, and anything over 450lb-ft (at wheels) below 4000rpm is getting into rod bending range. We use water/meth because our premium petrol is very low octane and quality. We have essentially stopped tuning for race gas as we can achieve peak torque timing with stock compression using the water/meth mixture. The water/meth injection is beneficial at any horsepower level in these cars as temperature control is the key to horsepower in this specific system.
Jason Petek
PNW, USA
PNW, USA
Looking at the torque graph, it doesn't look like you get much below 4k rpm and it seems to come in very slowly - more like a NA car?These turbo's are designed to spool faster then RS6's
What does the RS6 turbos torque curve look like then?
Here's a comparison with K04's (albeit on an S4)
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
how many psi on that stg 3???
Rs4 b5 06/2001
custom remap - KW V3 - Hotchkis Sways - ASP DTS with poly mount - 034 Street Mounts + Snub with bracket - Apikol rear diff mount and bushes - Gutted precats - DUH Fmic kit - 360x32 floating discs+brembo 6-pot at the front - 710Ns - OEM 18 Hard wheels - JHM shifter/linkage/spring etc - Podi.ca Boost Gauge - Powerflex Bushes - Afterrun mod -
addictmotorsport
I know, but that shouldn't have much of a bearing on the shape of the torque curve??? Here is the graph from the addictmotorsport site.The chart you have shown is horsepower and torque at the crankshaft. Our chart is horsepower and torque at the wheels.
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Users browsing this forum: Google [Bot] and 93 guests
