acronyms
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
shineydave
acronyms
Post by shineydave » Wed Feb 21, 2007 1:49 am
there's been a few posts recently where posters got confused about what system did what so here's some explainations trawled from the net, please feel free to add to the list.
ABS. Anti-Lock Braking system, i think everyone knows this one already
ASR. Anti Skid Control, works in conjunction with ABS, For today’s typical high-torque engines, a form of wheelslip regulation or traction control (ASR) can increase both comfort and safety, particularly on surfaces with differing coefficients of friction or on slippery roads. It makes smooth starts and acceleration possible through all speed ranges without wheel-spin or fishtailing.
ASR only operates in conjunction with the electronic accelerator (fly by wire) and uses components of the anti-lock braking system (ABS). If one wheel suddenly begins to rotate faster than the others (slip), ASR intervenes in the engine management system and reduces power until the wheel stops spinning.
ASR improves traction and can help the driver maintain control even if the limit of adhesion is inadvertently reached while cornering. In addition, it reduces tire wear. ASR activation, is indicated by a flashing light in the instrument cluster; it works with the electronic differential lock (EDL) and it is also part of the electronic stabilization program (ESP). ASR can be deactivated with the ESP switch
ESP. Electronic Stabillity Program, The electronic stabilization program (ESP) increases vehicle control in situations near the vehicle’s limits. It reduces the risk of skidding and helps to keep the vehicle on course. ESP recognizes the course desired and the car’s reactions. Through brake application at individual wheels, it generates one-sided forces which help the car to move in the desired direction. The ESP program uses other driving aids: the anti-lock braking system (ABS), electronic brake-force distribution (EBD), the electronic differential lock (EDL) and the traction control (ASR) system, and is permanently engaged.
Note:
ESP cannot suspend or extend limits imposed by the laws of physics. If a driver exceeds the capabilities of the suspension system and ESP, even ESP cannot prevent loss of control and an accident.
EDL. Electronic Differential Lock. The electronic differential lock (EDL) permits smooth, comfortable starts on road surfaces that do not have a uniform coefficient of friction. If a wheel starts to spin, EDL brakes it as necessary so that power is transmitted to the wheel with the better traction. EDL reduces tire wear and works up to about 40 km/h (quattro® : up to about 80 km/h). EDL is part of the electronic stabilization program (ESP) and the traction control (ASR) .
EBD. Electrionic Brake-force Distribution. Electronic brake-force distribution (EBD) and the anti-lock braking system (ABS), constitute one unit inasmuch as they share a number of the same parts. EBD ensures maximum braking performance at the front and rear wheels and under normal conditions it prevents the rear-end from braking away because of over-braking. The system counteracts “fading” as a result of overheating.
Teutonic_Tamer
Post by Teutonic_Tamer » Sat Apr 28, 2007 11:29 am
Just to add a bit more technical detail: :thumbs:
ABS: monitors each wheel individually, and prevents indvidual wheels from locking, under braking.
ASR: commonly called Traction Control. This is basically nigh-on redundant on permanent 4 wheel drive vehicles. It actually senses differences between a driven axle, to a non-driven axle - and would limit power (torque actually) to the driven axle. On quattros (only with Torsen, and not Haldex), the Torsen centre differential takes care if this, purely on a mechanical basis, without any electronic intervention. This works during acceleration.
ESP: on the B7 RS4, this uses the Bosch 8.0/ESP system, and CAN be switched off :wink:
EDL: only works on driven axles. Monitors differences between left and right wheels on the same driven axle, and applies braking effort to the wheel which is rotating faster (spinning) than the other.
EBD: in technical terms, this controls the brake bias between front and rear axles. On non ABS/EBD systems, the braking effort to the rear wheels was limited mechanically, by either load sensing valves, or pressure limiting valves. With the advent of electronic braking systems, the actual mechanical components of rear brakes are now "over-engineerd", and any failure of the ABS system, which permanently illuminates the warning light, then there is no control of the bias - and can result in a very dangerous situation of rear brakes locking up, even under light pedal application.
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
NumberoftheBeast
Post by NumberoftheBeast » Wed Jul 02, 2008 10:28 am
Can someone explain the acronym DRC???? :audibash: :lol:
GardinerG
Post by GardinerG » Wed Jul 02, 2008 10:41 am
NumberoftheBeast wrote: Can someone explain the acronym DRC????
Sure, here: http://audisrs.com/about163.html :lol:
NumberoftheBeast
Post by NumberoftheBeast » Wed Jul 02, 2008 10:52 am
Cheers :lol:
911 Turbo
Subaru Impreza WRX
TopBear
Post by TopBear » Wed Jul 02, 2008 3:17 pm
NumberoftheBeast wrote:Can someone explain the acronym DRC???? :audibash: :lol:
DRC = Duff Ride Control
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
NumberoftheBeast
Post by NumberoftheBeast » Thu Jul 03, 2008 10:22 am
Distressful, Rocky Car?
911 Turbo
Subaru Impreza WRX
TopBear
Post by TopBear » Thu Jul 03, 2008 12:13 pm
DRC = Disturbingly Ropey Components
GardinerG
Post by GardinerG » Thu Jul 03, 2008 12:56 pm
Audi "Doesn't Really Care"
Audi "Doesn't Read Complaints"
Dire Reliability Concerns
Dangerous, Rubbish and Clanky...
NumberoftheBeast
Post by NumberoftheBeast » Thu Jul 03, 2008 2:02 pm
LOL; think I have started something.
ESP = Effeminites! Speed Prevention.
911 Turbo
Subaru Impreza WRX
WAFWOTTBI
Post by WAFWOTTBI » Mon May 31, 2010 8:34 am
..dynamic ride control,hydraulic suspension system,im new owner,no more knowledge... :(
Return to “Audi S and RS Ownership”
