Movit Brakes and Warning light
2.7 V6 30v biturbo - 380 bhp
Tomson
Post by Tomson » Tue Jul 01, 2008 10:30 pm
Guys,
Cleaned the discs this evening there was a fair amount of <beep> on them. Feel a bit of an amatuer and wonder now why I did not clean them earlier. Have not test driven as yet as it started to piss down. Also front pads are virtually at there limit, sourcing a second hand set to try and will report back once have new(2nd hand) pads and clean discs.
One thing I did not get around to doing was drilling the holes through, any ideas on the size? They are full of deposits and could do with a clean also.
simon_golf_tt
Post by simon_golf_tt » Wed Jul 02, 2008 9:09 pm
You can get Textar 911 pads from Euro Car parts for £80 that fit.
IIRC the holes are 5mm - should be fairly obvious though :-)
2006 Sprint Blue RS4 Avant (for sale)
2007 A6 3.0TDI LeMans saloon
2001 Misano RS4 (gone)
2001 Noggy RS4 (gone)
Tomson
Post by Tomson » Thu Jul 03, 2008 8:18 am
Any idea on the part code at Euro Car parts, I have been looking and searching through the forum for the correct spec pads for the 4 pot Movit kit. I have found 993 turbo pads, 996 early turbo pads, GT2 pads, GT3 pads - which one? Most on Euro car parts are £60-£90 but the GT2 pads are £216!.
I was going to order part code;
TEXTAR n/a 101330210 BRAKE PAD SET TEXTAR NOT FOR M450 CERAMIC BRAKES front pad set up to 02 model
These are £62.00. Johnw uses Mk1 GT3 pads on his Movit 4's.
or the 993 turbo pads, part code;
TEXTAR n/a 101330130 FRONT BRAKE PADS 911 Turbo 93-, 928GTS 92-96
pictures of my brakes can be seen here;
http://www.ingramnewell.com/rs4_shots.htm
Cheers all.
Tomson
Durit
Post by Durit » Thu Jul 03, 2008 12:23 pm
hello
you have the 4M6 front kit: 996 GT3 (mk1), 996 turbo
and you have the 4S1/4S2 rear kit: 993 biturbo rear or 993 (non turbo) front, it is the same calipers.
The 993 GT2 calipers are the "big red", they look like your rear calipers, but biggest. The pads are higher.
The 933 GT3 (mk2) and 996 GT2 are the same calipers, 6 pots = Movit 6M1
For front you need (porsche) 996 351 949 12
RS4 mtm 460 "safety car", Milltek, Koni, Mov'it 6/380-4/322, teamDynamics wheels ------- S6 plus, mtm, H&R, Koni
I'm french (nobody's perfect) sorry for my bad English!
Tomson
Post by Tomson » Thu Jul 03, 2008 5:40 pm
Many Thanks,
Tom
Tomson
Post by Tomson » Sat Jul 05, 2008 9:53 pm
Have ordered the new pads from Euro Car Parts.
Any tips on changing the pads, I hear it is a five minute job.
I was thinking easing apart the old pads with something, then pulling the pin and removing the old pads, putting the new ones in and replacing the bar and pin? Is it really that easy?
Tomson
simon_golf_tt
Post by simon_golf_tt » Sat Jul 05, 2008 11:44 pm
Yes its that easy :)
Just checked and the "euro car parts" part number for the textar pads I have is 101330210 - £55.65 + vat when I bought them.
Tomson
Post by Tomson » Mon Jul 07, 2008 9:13 pm
UPDATE: Pads arrived today and were fitted this evening, also took the oppprtunitty to drill the holes (5mm as suggested)
Took the car out on a test drive and no more issues. It's like night & day, the flip of a coin, black & white etc etc.
Well Chuffed, many thanks for all the help.
Tomson
simon_golf_tt
Post by simon_golf_tt » Mon Aug 04, 2008 10:38 pm
I said I would post how I got on fitting the B7 RS4 discs with the Movit calipers. This went extremely well. If you want to know the specifics, follow the link below.
http://audisrs.com/sutra14091.php#14091
