Cool, i'll have a look around for a decent meeting place for saturday afternoon.mbelle wrote:I'd be up for a mini meet in Leeds - missus wants to see some friends over there anyway!
Maintaining an RS4, what next?
: RE: Maintaining an RS4, what
- quattrokid1
- Top Gear
RE: Re: RE: Re: RE: Re: RE: Re: RE: Maintaining an RS4, what
what time and where?
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
cool, glad it is sorted, definitely need to keep up with maintenance on the forced induction cars.
Hope you get a through health check
G
G
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Maintaining an RS4,
Whatever suits you and mbelle. Anytime after 11.30 is fine with me, thinking Grangefield Industrial Estate would be a good meeting place as its dead easy to find and my work is there. Two pubs 10 metres apart for refreshments quite handy. Hoping my supersprint exhaust will have arrived so you can have a nosey, probably ages before i get around to actually getting it on the car!quattrokid1 wrote:what time and where?
- quattrokid1
- Top Gear
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Maintaining an R
wouldnt know it from anywhere else, just need a street name or postcode for the satnav
sounds fine by me Lee
Audi 100 2.2E SOLD
Audi 100 2.2E SOLD
I'm quite easy - I know Leeds a little, particularly coming off the M621 nr City Centre/Armley (although Armley probably isn't a good area to meet)...
MB
MB
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Maintaining
I'll PM you the meet address. Its just off Stanningley Bypass, thinking about 12ish?mbelle wrote:I'm quite easy - I know Leeds a little, particularly coming off the M621 nr City Centre/Armley (although Armley probably isn't a good area to meet)...
MB
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Maintain
Sorry I didn't make this lads (well, I did, but 3 hours too late), but problems between me and the missus were the cause...
Hope you had fun...?
Marcus
Current: A C6 Audi
Previous: A B5 Audi
Current: A C6 Audi
Previous: A B5 Audi
jimbo1234567
- 5th Gear
the after run pump is an auxillary electric water pump and an aux fanbehind the radiator. these are switched by a temp sensor which sits in the water line down the back of the engine. when the engine is turned off and the engine is still at a certain temperature the switch cuts the pump and fan in for 10 mins to get rid of the heat as water is circulated round the engine and turbos, the mod is just another switch with a lower temp switch on or you can do what i did and disconnect the switch and connect the 2 wires together . this cuts the fan and pump in every time the engine is turned off regardless of temp or how long its been running for 10 mins. the n75 is a valve which is controlled by the ecu which dictates how much boost the turbos produce
665 bhp + 586 lbft...
jimbo1234567
- 5th Gear
its under one of the carbon engine covers, the middle one i think. its a black valve with 3 pipes going in
No symptoms Flashyq, but bought mine 12 mths ago with 74kms and went through the exercise of changing O2 sensors (all 4), MAF, and DVs, pressure test, a few vacuum hoses that had deteriorated.
I simply thought I saw something in this thread that I may have missed (like the N75), and first time I heard of the after-run factory equipment - they really didn't leave anything out on these cars !! ... and a better solution than turbo timers too.
Can you tell me if the N75 deteriorates over time without detection by VAGCOM??
Regards,
GB from downunder
GB from downunder
jimbo1234567
- 5th Gear
i changed mine as a matter of course as they can go off and they are only a cheap item
Users browsing this forum: No registered users and 139 guests
