Central Conv. Fault Code Address 46 (B7 RS4)
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
rjkflyer
Post by rjkflyer » Sat May 31, 2008 5:09 pm
Any idea what this means:
1 Fault Found:
01616 - Signal wire to Interior Monitor
49-10 - No Communications - Intermittent
Thanks !!!
rjkflyer
RE: Central Conv. Fault Code Address 46 (B7 RS4)
Post by rjkflyer » Thu Jun 19, 2008 8:29 pm
Ummm..... anyone...???
Maybe rear window break glass detector???
Sebastian
Post by Sebastian » Thu Jun 26, 2008 12:52 pm
There should be a separate interior monitoring control module, but without seeing a full scan its hard to give you anything detailed. However, it is an intermittent fault - did you have any problems except the code itself?
Sebastian @ Ross-Tech.com
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 19 guests
