Ride Height - How low to go ?
- WeaselRS6saloon
- 1st Gear
Hi,
I recently had KW's superbly fitted by Grizz at Unit 20 and I have been playing about with the ride height, but cant make my mind up where to set it at.
Just wondering what other people have their cars set at ?
KW Paperwork says between 340mm and 360mm from centre of hub to wheel arch.
I have the front set at 337mm (outside of what the paperwork says I know) and the back at 343mm (give a bit extra for the kids!).
Any ideas / opinions welcome....................
RE: Ride Height - How low to go ?
Can you post a pic? How does it look at 337?
Drop it like its hot
- NumberoftheBeast
Fo shizzle ma nizzle.
- WeaselRS6saloon
- 1st Gear
Re: RE: Ride Height - How low to go ?
Photos attached I hope !Rupert wrote:Can you post a pic? How does it look at 337?
RE: Re: RE: Ride Height - How low to go ?
Ive never been a big fan of lowered cars...esp for such a big car it looks..well chaved. imo of course.
- Spacecowboy
I think its very nice to lower the rs6...
dont you get any knocks on the bodywork , being that low ?? , and how bumpy is it !!!
phil
phil
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Lower than mine .
Unit 20
0151 3366888
0151 3366888
- Spacecowboy
What suspension have you got and do you run it hard or soft.Mine is higher than yours and bounces/crashes about all over the place!!Spacecowboy wrote:only on the inside fander you must work a little bit !philroach wrote:dont you get any knocks on the bodywork , being that low ?? , and how bumpy is it !!!
phil
it drives much softer as with the original drc...
MTM Stage 2,Billi PSS9's,Milltek,MTM Bimota's
- Spacecowboy
- ElginEdition
Users browsing this forum: Google [Bot] and 154 guests
