EBC yellow stuff pads
are they any good ? i understand you can`t get them to fit b5 rs4 .
but can get them for rs6 .
i have rs6 callipers so thats fine. they only do the red stuff for back brakes
RE: EBC yellow stuff pads
I use them on my B5 S4, obviously losing the wear sensors. They're pretty good, but I'm still on stock calipers so the pads weren't the real weak point. They did squeal a bit for the first few hundred miles, but after that they were just like any other pad with a bit more bite.
2000 Nogaro S4 Saloon
so what your saying is i would have to have no wear sensor ?
I've got them and they have got the wear sensors . Seem quite good .
Unit 20
0151 3366888
0151 3366888
would it be ok to have yellow on front and red on the back then ?
you can get them for the RS6 (B7 RS4), I have a set here, they have wear sensors on them.
pad difference front and back shouldn't be a major issue, may just seem to affect your bias as the front bite harder than the rears are expecting
Sorry but In My Humble Opinion EBC are <beep>. Feeling less, soft, fading, poor.
You get what you pay for.
Get Pagid. Sorry don't mean to be negative.
I've heard that it is bad to mix different brands + types of pad front + rear. Especially in the case of a harder/higher temperature compound on the front and softer on the back. It can cause imbalance when cold braking if the fronts are not up to temperature, so the rear of the car will become unstable. For the relatively small price involved, I'd get the yellows or reds all round, not a mix.
Re: RE: EBC yellow stuff pads
Got to agree don't last either. Pagid or DS2500 can't go wrong and never fade especially the Ferodo's. They can warp discs though!!flashyg wrote:Sorry but In My Humble Opinion EBC are <beep>. Feeling less, soft, fading, poor.
Users browsing this forum: No registered users and 11 guests
