Mad Maf
Mad Maf
Changed the air filter today, managed to lose somewhere in the depths of the engine bay one of the clips that holds the Maf in the airbox - good old tie wraps!
Had to virtually remove airbox to do up bottom clip, same as last time.
Anyway went out and did some logs to check everything was looking ok and recorded a peak maf of 232.06 - 290bhp???
Car as far as I know is std and spec boost vs actual was spot on.
Have I broken something?
RE: Mad Maf
Nope. Does sound like a stage1 witha dodgy DV valve...?
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: Mad MAF
It is either a stage1 running badly or a std car with N75 tweaked to max.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: Mad MAF
N75 was replaced same time as DV's, car has also been to Doug for a health check and once he had sorted out my dodgy N75 connections he didn't say he thought it was modded.
RE: Mad MAF
Also I would have expected the ecu to be calling for more boost than it does even if the turbos couldn't give it.
RE: Mad MAF
boost is stock. could be a leak causing more air to be sucked in. Could be maf reading wrong - they can read high as well as low.
http://www.MRCtuning.com
- mikeyquattro
- Top Gear
Re: RE: Mad MAF
My Maf was over reading.... IIRC it was 360ish. Should have been 325-330Doug_S2 wrote:boost is stock. could be a leak causing more air to be sucked in. Could be maf reading wrong - they can read high as well as low.
Doug diagnosed and changed accordingly
Tomorrow is another day
RE: Re: RE: Mad MAF
Thanks all.
MAF is only about 14 months old but I guess that's no reason to think it may not be faulty.
Just seems odd that peak has only ever been 220 until I changed the air filter so maybe a leak due to my amateur mechanics
Had a poke around and the MAF housing wasn't pushed fully home into the airbox but everything else looked tight.
Won't be able to log again before the weekend.
RE: Re: RE: Mad MAF
I've got exactly the same problem (MAF peaks at 232) so please update if you ever find the cause. Like suggested I'm guessing air leak but damned if I can find it...
