Buy HEX-USB+CAN lead or not?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
frazered
Post by frazered » Mon Jun 09, 2008 12:39 pm
I have a A4 96 so have looked at the KEY-USB rosstech lead, but is it worth going for the HEX-USB+CAN instead for forwards compatibility and resale?
thanks
frazered
RE: Buy HEX-USB+CAN lead or not?
Post by frazered » Mon Jun 09, 2008 3:04 pm
bought the HEX-USB+CAN now - seems to offer the best solution
Norrs2
Post by Norrs2 » Thu Jun 19, 2008 8:07 am
Which Version of Ross-Tech VAG-Com is best for the B5 A4 and is the Lead you mention here the best suited?
Thanks in advance!
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
TopBear
Post by TopBear » Thu Jun 19, 2008 10:00 am
Norrs2 wrote:Which Version of Ross-Tech VAG-Com is best for the B5 A4 and is the Lead you mention here the best suited?
Thanks in advance!
If it's only going to be used for a B5 A4 (S4\RS4) etc, then the KEY-USB will be adequate. I upgraded to the HEX-USB-CAN for compatibility with newer VAG cars as I have a MK5 Golf, but if this isnt a requirement for you then the KEY cable offers just as much functionality as the HEX one for your car.
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Norrs2
Post by Norrs2 » Thu Jun 19, 2008 12:47 pm
Thanks in advance!
Thanks TopBear!
Primarily, this is for a mate, and he want's to be able to diagnose any VW/Audi prior to 2001.
I have a cable (bought on ebay) which also has the 2 separate connectors for Audi's from as early as 1993 (& OBDII). The Rosstech version 331 I think, would not read a 1998 A4 2.4 last night. I don't know whether this is because we were using the wrong Rosstech version of Vagcom or that my cable is not compatible, even though I have a USB adapter as well as a regular Comms port. It would not work with either.
Your thoughts would be appreciated!
PS. How did you get on with the detailer?
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
TopBear
Post by TopBear » Thu Jun 19, 2008 1:19 pm
Norrs2 wrote:
Thanks in advance!
Thanks TopBear!
Oooh, dunno about the older VAG cars, perhaps this table explains it clearer than I'd be able to http://www.ross-tech.com/vag-com/interfaces.html
Is the cable you've got a genuine Ross-Tech VAG-COM cable or eBay copy?
Car looks great, Dave did a sterling job on my too.
Pics here http://www.rs246.com/index.php?name=PNp ... ic&t=71155
Norrs2
Post by Norrs2 » Thu Jun 19, 2008 1:38 pm
TopBear wrote:
Norrs2 wrote:
TopBear wrote: If it's only going to be used for a B5 A4 (S4\RS4) etc, then the KEY-USB will be adequate. I upgraded to the HEX-USB-CAN for compatibility with newer VAG cars as I have a MK5 Golf, but if this isnt a requirement for you then the KEY cable offers just as much functionality as the HEX one for your car.
Thanks TopBear!
Cable is an e-bay copy, but worked on my earlier S2 and mates Audi 100 S4.
Car looks the biz by the way!!
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Return to “DTC / VCDS”
