URGENT front suspension, how do you get it off???????
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
fil
Post by fil » Tue Jun 17, 2008 6:53 pm
need to change to arms, but im stuck and pissed off now, every dam bolt fouls something!
need to get the arm off as the 100mm bolt is siezed in proper good, so need the lot in a vice to smash it out.
but the main bits is the rear lower arm, bolt fouls the underside of the car?
where do i need to go next to get it all off.
+ is the abs sensor cable pluged behind the dash somewhere, as that runs through the dam arm.
pictures to make sence of what the hell im on about :oops:
99 S4 minging blue avant
Stigter
RE: URGENT front suspension, how do you get it off???????
Post by Stigter » Tue Jun 17, 2008 7:03 pm
Get some heat on it to take the long pinch bolt out. Drop subframe a little to get lower bolts out. undo strut.
Or do what I did and watch someone struggle while drinking tea with a pack of milk chocolate malted milks.
S4
Post by S4 » Tue Jun 17, 2008 8:29 pm
yes mate, as said drop the sub a little, that big bolt, just undo it a bit and get a lever on the wishbone. that lower wishbone, the banana shaped one is a little silly, the way you have to drop the rear on the frame is crap!. You will see what I am saying by putting a leaver in the top.
I do hope you are using plus-gas on the bolts, and not silly wd40, they are like chalk and cheese.
Darren
Mikey-S
Post by Mikey-S » Tue Jun 17, 2008 8:48 pm
Be careful with the seized bolt at the top of the upright, I broke a chunk off an upright once when I was trying to hammer a bolt out. I've changed my technique since then...
If it's completely seized then you could always lower the top housing to undo the two wishbone bolts and take off the upright complete with wishbones..
Mike
fil
Post by fil » Tue Jun 17, 2008 8:55 pm
got the lot off, lowered the subframe as said,
the bolts shoot as when i tapped it (with a nut on to protect the thread ) it bent a little.
just sorting my dinner, then poping into my work place, to get the whole lot in a vice and tap it out, hopefully!
Stigter
Post by Stigter » Tue Jun 17, 2008 9:05 pm
Well done Fil :-) you deserve dinner
fil
Post by fil » Wed Jun 18, 2008 1:09 am
nearly 3 good hourts later 1AM in the morning ive just got back home from some very slow but carefull drilling, the bolt exsists no more!
up in a few hours to put it all back together again!
fil
Post by fil » Wed Jun 18, 2008 5:30 pm
didnt get on it until 2 but all drivable now.
got what i presumes an abs warning light up ( from where the sensor was disconected? ) or ( not put back correctly? )
And i cant find my vagcom lead!!!!!!
planed to reset it and see if it comes back before i play around with it.
Alps
Post by Alps » Thu Jun 19, 2008 10:09 pm
Nice one Fil. You showed some perseverance there dude and it seems to have almost paid off :thumb: Just hope you get the ABS warning sorted.
01 RS4, Milltek, Dahlback Racing rears, RS6 fronts and a few bits to be added.
Also, as I hate driving, my toy to play with - a Honda CBR F Sport
fil
Post by fil » Sat Jun 21, 2008 2:55 pm
still cant find my vagcom lead!!!!!!!!
anyone close to rainham essex with one???
okkim
Post by okkim » Mon Jun 23, 2008 8:13 am
The ABS sensor is probably too far away now. Push it in as close as possible (but not touching), and it should work.
docurley
Post by docurley » Tue Jun 24, 2008 9:37 am
No need for VAGCOM to clear the fault if it is fixed as it will run a diganostic every time you start the car and will clear if fault is gone.
Users browsing this forum: No registered users and 99 guests
