Hi guys, after having Recaro pole positions fitted the airbag light is permanently illuminated, my passengers look at it nervously.
I've tried fitting resistors but no dice, I guess the computer may need to be reminded theres no seat airbag.
Can anyone recommend somebody in the Reading area that fan rectify it?
Cheers!
Steve
Pesky airbag warning light
RE: Pesky airbag warning light
Should be fine with resistors, you just have to find the right value resistor. I'm not sure of the value, I gues it's just a case of trial and error. The airbag system will need the fault codes erased every time in order to switch out the light, even if the fault has gone the light will stay illuminated for around 50 ignition cycles.
Whatever you do, don't measure the resitance of the old seat airbags..... you can ignite the airbag!
Mike
Mike
Can you recode the airbag controller using Vag Com to not expect seat airbags?
No. There are only a couple of options regarding coding an airbag unit, and all codes look for front seats. Besides, I'm sure an airbag unit can only be coded once.
Mike
Mike
- Top Gear
