Coolant Issues
2.2 I5 20v turbo - 315 bhp
afhgus
Coolant Issues
Post by afhgus » Mon May 12, 2008 1:48 pm
Hi ALL
I am finding my coolant level requires topping up on a regular basis, ( which is beginning to annoy me) as everything that can be checked has been, head gasket replaced at great expense! Radiators replaced, hoses tightened, pressure tested and so on. I have been told this is normal for the age of car. I use daily with a mixture of driving hard and traffic jam stop starts. Its kept outside.
Has anyone else got this issue? Would be great to know.
thanks for reading
Angus
M690LYY Volcano black,130000 miles,standard,everyday transport, new rear discs, new door trims, replaced radiators x2, front/rear shocks(OE) + suspension bushes, recent alarm, undersealed, new exhaust/head gasket, pulls like a train. for sale soon
DickyC
RE: Coolant Issues
Post by DickyC » Mon May 12, 2008 2:12 pm
Hey Angus
This won't help you find where it's going but should dispel the "normal for the age of the car" nonsense. Mine's used regularly (10K last year) and doesn't need topping up between services.
DickyC
Volcano Black 1995 RS2. Standard.
Gone - but understood to be alive and well and living in Cornwall.
DickyC
RE: Coolant Issues
Post by DickyC » Mon May 12, 2008 2:13 pm
And is on 138,000 I should add...
afhgus
RE: Coolant Issues
Post by afhgus » Mon May 12, 2008 6:23 pm
Hey Dicky
Thanks for the response, I've just had a nose around my secondary radiator which looks like there is some nasty bits of corrosion on it, inside next to the belts, maybe I have a tiny leak? Glad you don't have these issue though, this radiator was replaced 4 years ago....
cheers
DickyC
RE: Coolant Issues
Post by DickyC » Tue May 13, 2008 9:24 am
A tiny weep will evaporate leaving little evidence until you go looking for it. And it sounds like that's what you've just done. I think there's an element of luck with rads. Mine were recored a few years back (before I bought it) and are okay but you bought new ones and have a leak.
By the bye, in the pre-Ford days, every new Aston Martin left the factory with Bars Leaks already in the cooling system! That might be a way to go.
afhgus
RE: Coolant Issues
Post by afhgus » Tue May 13, 2008 7:30 pm
Hi Dicky
On Re-evalulation I think the rad might be ok despite cooling fins looking crumbly it is relatively new. I've had suggestions it could be the turbo hoses under the inlet manifold that could be it. Anyway I'm going to monitor it and live with it until I can get it looked at. I'll let you know what i find,
cheers
A
Corey
RE: Coolant Issues
Post by Corey » Wed May 14, 2008 11:05 am
With the car cold have the coolant system pressurised (no more than 1Bar) and any leak will be evident. If it is a small leak and the car is hot it will evaporate and not leave any trace.
Have the coolant tested to see if the head gasket has gone also.
Corey
80seq
RE: Coolant Issues
Post by 80seq » Tue Jun 10, 2008 8:29 am
Hi I have same issue, bloody annoying. I had mine pressure tested but showed no leak. While doing an oil change however I removed the under body drip tray and found evidence of a small leak directly below radiator but can't see/work out where it is coming from!
DickyC
RE: Coolant Issues
Post by DickyC » Tue Jun 10, 2008 11:55 am
Did I mention Bars Leaks?
Bars Leaks Radiator Stop Leak, ideal for weepy rads.
afhgus
RE: Coolant Issues
Post by afhgus » Tue Jun 10, 2008 5:03 pm
I've just discovered a nice pool of coolant underneath main rad, this was visible from the off side looking through to under the front spoiler from the front wheel, why didn't I see this before! Its booked for the work as we talk. BTY I plan to sell my car in later September time. :boohoo: 5 years of ownership and my bank account is calling time...
A
afhgus
RE: Coolant Issues
Post by afhgus » Wed Jun 18, 2008 10:07 pm
It appears a bracket worked lose under the main rad. Radiator out job to see...sigh
AH
Users browsing this forum: No registered users and 13 guests
