Clutch advice needed.
Hi folks,
I'm in the middle of getting my clutch replaced, I'm helping to do it at my mates garage, got the box off and my flywheel and slave cylinder are both knacked.
The flywheel has 110mm play in the cush assembly, standard tolerance is 10mm so I need a new 'un.
I am putting a RS4 clutch assembly in, so can I use an RS4 slave cylinder?
Anyone in UK with a lightened flywheel in stock?
I can get a new standard flywheel monday afternoon but would prefer a lightened one if I could get it in the same timeframeish.
RE: Clutch advice needed.
You don't have to change the slave cylinder, it is the same in S4.
Re: RE: Clutch advice needed.
Ok thanks for that okkim.okkim wrote:You don't have to change the slave cylinder, it is the same in S4.
Does anyone know if I could leave the existing flywheel in with that play and the new RS4 clutch, the engine is coming out for turbos etc within 1000miles, when I will replace the flywheel with a lightened version, I need the car for work and need to work to pay if you see what I mean
RE: Re: RE: Clutch advice needed.
If you don't push the car hard, the old FW will be fine if it has working ok before that. Especially when you have so little time to wait for proper one.
I have a light weight fidanza one available immediately, where are you?
I think that the Fidanza is good FW, I have installed many of those.
Re: Clutch advice needed.
110mm play, what that all about. where are these measurements taken.
Darren
Darren
snadge wrote:Hi folks,
Re: RE: Re: RE: Clutch advice needed.
grr... to late mate, I have had a standard one delivered now.......dummi wrote:I have a light weight fidanza one available immediately, where are you?
It is the rotary movement of the internal drive plate on the "shock absorber" assembly when rotated against the outer part of the flywheel.S4 wrote:110mm play, what that all about. where are these measurements taken.
Darren
The new one I have when you apply a rotary motion on this part, there is minimum movement, on the old one there is 110mm+ rotary movement with feeling of something catching internally.
Audi tolerance is 10mm>
RE: Re: Clutch advice needed.
cool.... where are the instructions- specifications for this, Bentley workshop manual? im looking for a good manual for the boat... they are not really talked about much.
Darren
Darren
Re: RE: Re: Clutch advice needed.
I could tell something was up with the flywheel when we inspected it, so a quick call to Audi was made.S4 wrote:cool.... where are the instructions- specifications for this, Bentley workshop manual? im looking for a good manual for the boat... they are not really talked about much.
Darren
RE: Re: RE: Re: Clutch advice needed.
Is it from side to side 10mm, or from the center?
come on guys.... where are the super workshop manuals on these things....
Darren
Darren
Users browsing this forum: Majestic-12 [Bot] and 52 guests
