Ran VAG on my car. Found reference: SPORTEC ST01/02
Is this a normal reference under Engine Electronics or does it mean my car has been pampered by Sportec (i.e. tuning) at some point in his life? I'm curious since I did not expect to find anything beyond Audi or Bosch references there.
What blocks should I measure to get a definite answer if my car is stock or not? What values should I expect from a stock car on these blocks?
TIA
TIA
- Top Gear
RE: Ran VAG on my car. Found reference: SPORTEC ST01/02
Sounds like you must have had it remapped at some point.
Mine says MRC when I scan the Engine module.
You don't mention what car you've got.
Where exactly did you find that?
Sebastian @ Ross-Tech.com
I scanned for DTC's, and it's in the 1st line of the first ECU read (Engine Electronics):
SPORTEC ST01/02 G 0001
DTCs: 0
P/N: 8D0 907 551 K
DTCs: 0
P/N: 8D0 907 551 K
Re: RE: Ran VAG on my car. Found reference: SPORTEC ST01/02
Interesting, as I've also had my car remapped by MRC as well, however VAG-COM displays mine like thisR12 wrote:I scanned for DTC's, and it's in the 1st line of the first ECU read (Engine Electronics):
DTCs: 0
P/N: 8D0 907 551 K
Monday,02,June,2008,22:10:29:31958
VCDS Version: Release 805.0
Data version: 20080529
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WUAZZZXXXXXXXXXXX
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 K
Component: 2.7l V6/5VT G04 0001
Coding: 10711
Shop #: WSC 63351
WUAZZZXXXXXXXXXXX AUZ7Z0A1234567
No fault code found.
Readiness: 0000 0000
RE: Re: RE: Ran VAG on my car. Found reference: SPORTEC ST01
To be more specific, I use VAD Mobile (software app used to be ProDiag via Shade Tree Software). Output lines may differ slightly but it has equivalent functionality. I used the same app when I had my B5 S4, and the references in any of the ECU's which showed anything related to a brand was either Audi or Bosch related. That's why I venture guessing my car may have undergone remapping.
What blocks can I meassure to be certain? I know boost (actual v. requested) but I don't remember which block was that (115?), and the other is 122 which shows torque.
R12: your car has Sportec software for sure, no need to check anything else, sportec are the only ones who use that denomination in VAG ID fields.
As for our (MRC) software, in general we keep it discreet and it doesn't display anything other than stock ID's when checked with VAG com
Probably I'm Stage 1 then. I will still check blocks just to make sure I'm not Stage 2 since the car has stock exhaust. Do you know if the ECU is constantly in this new remapped state or does Sportec have the type of software where you can actually activate it/desactivate it at will?
Some tuners do alter the component field to represent their modification, others alter the control module part number or the software version. IMHO a tuner should make it obvious i.e. by altering the software version. For example ABT does often do it like this...
Address 01: Engine
Part No SW: 4F9 ABT 401 L HW: 4F0 907 401 C
Component: 3.0L V6TDI G001AG A020
Coding: 0011372
(Notice the ABT in the part number as well as the A020 instead of 0020 for the software version.)
Address 01: Engine
Coding: 0011372
Does Sportec have the type of software where you can actually activate/deactivate at will? For example, toggle between Stock and Stage 1 by using the cruise control buttons.
